Towbar help
Hi all.
I am looking to hit a towbar on my 280 hatch, and because I don't want it in plain sight all the time, I was looking at the OEM ones.
Having searched for the code of the towbar that will fit on a hatch, I keep coming across the information that the same product fits on estate and hatch. Is this true ? Or the sites that sell these new don't have a clue ?
Another question would be, how do I know if the car is equipped for towbar ? Do I just check the fusebox, and if there is a wire coming out that fuse, it means I got all the cables and modules ?
I would def go with the OE one if you can deal with the price, a more complex install, and the relevant coding needed. It is however a hoot to use, provided you keep your fingers away when the spring retracts (ask me how I know) and make sure you extract it from time to time to clean and grease not only the ball, but also the folding mechanism.
I have added a "chopped" rubber ball protector, just the fact that is tucked in does not exclude it is subject to a lot of dirt, mine even shows a spot of rust forming up and this is on a 5yo car, I have been using towards extensevely for over 20 years on several vehicles and this is first time to me ...
I am planning before winter to make a detachble "hatch cover" to keep grime and filth out of the way.
Sorry for the longish preamble, back at you, my two Accessories' catalogue for the Superb (which I will be happy to email or share) do show different codes for hatch and combi. While the metal in itself I am sure is the same, I believe the cabling and wiring loom connections are in different positions, and thus different lengths, so no strange to have a different code. See attached photos for reference.
For an aftermarket towbar that "piggybacks" to the rear lights, or similar, it would make sense to list it as same product.
For the car prep, there appears to be a "tow car preparation" which from older posts appears to be with an uprated radiator and fan, and something else now I cannot remember (age, mostly).
See also it is shown in the attached.
Finally, I have seen and heard of cars WITHOUT any information for towing capacities in the VIN plate fitted in the door pillar. Check first that your has it, otherwise you would have legal problems in case you tow. I believe you can get away with it in case is only a bike rack or similar, but ....
The fact that they make this distiction at factory production level is an inenarrable shame, it is like when Fiat sells the Panda with "4 seats" but if you want the 5th with papework and belts, you gotta pay extra ... c'mon ☠️
If you want something invisible when not in use then a swan neck removable tow bar is another option and will be much cheaper, even with dedicated electrics and full coding.
Well because then you have to store it somewhere when not in use. Depends on how much you can afford, I guess. I have had 2 Superbs both with the OEM towbar, and it is pretty good. No complaints other than you do sometimes have to reach under to encourage it out. You certainly need all the electronics, otherwise the parking radar, rear traffic alert radar and manoeuvre braking will drive you crazy. And a camera with the "look down onto the towhitch" mode.
Both my 280tsis had an auxiliary radiator in the nearside wing area (RHD), not sure if that is a feature of all 280s or just those with factory towbars.
Well it goes in the boot in the spare wheel well for one and you then don't get mucked up when you fit it as it stays clean. As for electrics etc. If coded properly you still get all that you mentioned. I had an octavia with an OE bar and now have a Kodiaq with an aftermarket bar with dedicated electrics and there is absolutely no difference other than the latter was about half to one third of the price.
But each to their own and if you prefer the OE version that's fine... I just thought I'd make the suggestion as personally I think. It's overpriced and, given it's exposed to the elements and has a tendency to stick, seems under engineered.
I would not say is under-engineered, I think just like most things nowadays is designed by a fresh mind who plays mostly on simulations on a PC, or even worse, gives generic statements to some "AI CAD" and then passes on whatever designs comes out, and obviously on a budget controlled by someone that does not have an idea with side turns a left-hand screwdriver .... 🙄
Result is as expected.
It simply needs a cover for the darn hole in the bumper where the hitch resides. Curiously, neighbour's Tiguan has a similar retractable mechanism and after many years his is flawless, which means probably in Wolfsburg they had more budget ... or better "AI CAD" 😁
I am set on the OEM one if I do it, as I don't want to cut anything on the bumper, and I want it just to hide away when I am not using it.
Looking on ebay( as I want to buy it second hand) I can find the same code for one that was on an estate or a hatch, the only difference would be the last letter of that code, but I think that only is saying that is a revised version or not. The code they have is 3V0803881. If you could share the catalogues for estate and hatch, that would be great.
I know it will need coding and so all the electrics on the car won't go crazy when I connect a trailer, so don't think getting someone to code an original one will be way more expensive than an aftermarket one.
Regarding the plate on the piller, yes, I got that, plus the V5 stated the maximum towing capacity, so it should be fine from the legal point of view.
Edited by LeGrumpy
I don't want the faff of putting the neck, remove the neck. I had that type of towbar on my previous Superb, an MK2, and it was stuck in there. No matter what I did, it didn't want to come out.
Plus, I think on the MK3 it requires to trim the bumper a bit to put a swan neck towbar, and I want to avoid that.
5 minutes ago, leolito said:
That number is not matching the accessories' number listed above, so probably is for a "factory" genuine ... so there you go, see if this helps:
https://www.lllparts.co.uk/catalogs/skoda/CZ/SUP/851/8/804/804000
Thanks.
The link you gave me ( don't know why it didn't came back in my google search) gives me a lot of answers, as one towbar that I found has the letter A and one the letter D.
Funnily enough, I did emailed these guys a while ago, to ask them about the lead time on one of the codes I've found on their website, and they said they can't confirm it will fit my car if the part wasn't on my car when it left the factory.
Standard response, and understandable. Not easy to deal with the accountability if a wrongly ordered part is shipped - and fitted!
You seem to be a reasonable person, but the next guy might be unreasonably "complicated" ....
Good luck to get this towbar business done!
That additional radiator is a DSG cooler if it’s low down in front of the near side wheel arch.
Well, not on my car it isn’t! I am intimately familiar with it after I hit a badger and the plastic air scoop shattered and punctured the radiator. Lots of coolant came out, no oil!
Missed this and had to check - it doesn’t run the gearbox oil through the radiator; it has a heat exchanger and the coolant runs through that and the radiator.
  • 8 months later...
Hi @LeGrumpy, did you get an OEM towbar installed? I'm looking into it myself and wondering what the costs would be in comparison to a removable san neck at ~£750.
I didn't end up doing it in the end. Was a pain to find a second hand oem towbar for hatch, so I've abandoned the ideea
In case anyone finds this thread at a later date, I got quoted £1718 for the OEM retractable towbar fitted at my local main dealer, DM Keith.
@East_Yorkshire_Retrofits have OEM folding towbars for kodiaq listed on their website. they may well do for superb too. These are priced about £1500
Edited by Binx1310
No luck, they're not fitting any towbars at the moment
Recently Browsing 1
