Error Codes Lights Mulfunctioning
Hi all.
I have had my Skoda Octavia 2016 Rs wagon, I have had it recently serviced and brake rotors replaced.
Since this I have nothing but issues with error codes and light errors.
I have taken it back and they have cleared the codes twice and told me to buy some new globes.
What has been done or shorted out in my car to cause such a flip out of error codes and lamps.
See attached photos of progressions of errors when car turns on.
Right hand front light lamp strip not working
Left hand head lamp not working
Left hand parker not working
Left hand blinker not working
Right rear brake lamp not working
I'm unsure what the hell has gone on.
Edited by Bagley
Do you have LED lights or Halogen lights? It sounds like whoever has done the work has unplugged a number of connectors and didn't reconnect them. Look around behind the headlights and see if there are connector floating. Always use a good VAG specialist. General garages aren't good with VAG products.
Thank you , it looks like all fuses are sound and all plugs and globes are okay.
I cannot change the globe from blinker easily as I was going to swap it to other side and check again.
Anyone else wants to weigh in.
What say the Error Log when you Check this with OBD11 or something Else?
Are the individual items working?
Thanks for reply ,No they are not .
I don't have this test available just yet
Car Scanner ELM OBD2
Version: 1.121.0/401210/GP
DTC report
Connection profile: Skoda OBD-II / EOBDDate: 9/24/2025 1:25:00 PM
VIN: TMBKE9NE2F0186779
OBD-II
No DTC found.
19. CAN Gateway19. CAN Gateway
DTCs: 2
131598 [0x02020E] Archive (inactive)
U014000: Lost Communication With Body Control Module
Timeout_Node_0x0E_DiagAdress_09_BCM1
Status bits: 1
Priority: 2
Frequency: 1
Unlearning index: 169
Odometer: 75913 km
Date, time: 2025.09.23 22:28:55
Status: Confirmed
131619 [0x020223] Archive (inactive)
U104700: Control module for rear lid electronics, No communication
Timeout_Node_0x23_DiagAdress_6D_HDSG
Status bits: 1
Priority: 2
Frequency: 1
Odometer: 75913 km
Date, time: 2025.09.23 22:41:56
Status: Confirmed
09. Onboard supply control unit09. Onboard supply control unit
DTCs: 10
536853 [0x083115] Archive (inactive)
U112100: Databus missing message
HDSG_01 Datenbus fehlende Botschaft
Status bits: 1
Priority: 6
Frequency: 1
Odometer: 75913 km
Date, time: 2025.09.23 22:41:55
Status: Confirmed
06666 [0x001A0A]
B121715: Left low beam headlamp bulb, Open circuit/short circuit to B
Abblendlichtscheinwerfer links-Unterbrechung / Kurzschluß nach Plus
Status bits: 1
Priority: 1
Frequency: 1
Unlearning index: 125
Odometer: 75903 km
Date, time: 2025.09.23 00:15:13
Status: Test failed, Confirmed
12042 [0x002F0A]
B12C815: Right rear fog light bulb, Open circuit/short circuit to B
Nebelschlussleuchte rechts-Unterbrechung / Kurzschluß nach Plus
Status bits: 1
Priority: 2
Frequency: 1
Odometer: 75903 km
Date, time: 2025.09.23 07:37:36
05898 [0x00170A]
B12D015: Left turn signal light bulb, Open circuit/short circuit to B
Blinkleuchte links Seite-Unterbrechung / Kurzschluß nach Plus
Status bits: 1
Priority: 2
Frequency: 1
Odometer: 75903 km
Date, time: 2025.09.23 00:15:10
05130 [0x00140A]
B11E815: Left front turn signal bulb, Open circuit/short circuit to B
Blinkleuchte links vorne-Unterbrechung / Kurzschluß nach Plus
Status bits: 1
Priority: 2
Frequency: 1
Odometer: 75902 km
Date, time: 2025.09.23 00:08:22
09226 [0x00240A]
B122115: Left stationary AFS, Open circuit/short circuit to B
statische Abbiegeleuchte/Kurvenlicht links-M51-Unterbrechung / Kurzschluß nach Plus
Status bits: 1
Priority: 4
Frequency: 1
Odometer: 75903 km
Date, time: 2025.09.23 00:15:09
11530 [0x002D0A]
B12C315: Right brake light bulb, Open circuit/short circuit to B
Bremsleuchte rechts-Unterbrechung / Kurzschluß nach Plus
Status bits: 1
Priority: 1
Frequency: 1
Odometer: 75902 km
Date, time: 2025.09.23 00:07:58
19210 [0x004B0A]
B12EDF2: Right LED daytime running lamp and parking lamp LED module, Supply, open circuit/short circuit to B
LED-Modul fürTagfahrlicht/Begrenzungslicht rechts (Versorgung)-Unterbrechung / Kurzschluß nach Plus
Status bits: 1
Priority: 2
Frequency: 1
Odometer: 75902 km
Date, time: 2025.09.23 00:06:42
204546 [0x031F02]
B147A18: Remote key 2, Voltage too low
Funkschlüssel 2-unterer Grenzwert unterschritten
Status bits: 1
Priority: 4
Frequency: 1
Odometer: 75903 km
Date, time: 2025.09.23 00:15:33
132363 [0x02050B] Archive (inactive)
B140D13: Voltage supply, terminal 30, left, Open circuit
Versorgungsspannung Klemme 30 links-Unterbrechung
Status bits: 1
Priority: 1
Frequency: 1
Odometer: 75913 km
Date, time: 2025.09.23 22:28:48
Status: Confirmed
02. Transmission control unit02. Transmission control unit
DTCs: 1
10657 [0x0029A1]
P072600: Engine Speed Inp.Circ., Range/Performance
Engine Speed Inp.Circ. Range/Performance
Status: Test failed (current drive cycle)
03. ABS control unit
No DTC found.
01. Engine control unit
No DTC found.
04. Power steering
No DTC found.
05. Authorization system for access and starting the engine05. Authorization system for access and starting the engine
DTCs: 1
9519153 [0x914031] Archive (inactive)
Steuergerät fuer Heckklappe - kein Signal/Kommunikation
Status bits: 1
Priority: 6
Frequency: 1
Odometer: 75913 km
Status: Confirmed
08. Heater and climate
No DTC found.
10. Parking Assistant 210. Parking Assistant 2
DTCs: 1
13637426 [0xD01732] Archive (inactive)
U112300: Databus error value received
ESP - ESP_21.ESP_Systemstatus - Fehlerspeicher auslesen
Status bits: 1
Priority: 6
Frequency: 1
Unlearning index: 165
Odometer: 75902 km
Date, time: 2025.09.23 00:09:36
Status: Confirmed
13. Active cruise control
No DTC found.
15. SRS
No DTC found.
16. Steering column
No DTC found.
17. Dashboard17. Dashboard
DTCs: 13
16776960 [0xFFFF00] Archive (inactive)
ACC_02 keine Kommunikation
Status bits: 1
Priority: 2
Frequency: 1
Odometer: 75913 km
Date, time: 2025.09.23 22:28:53
Status: Confirmed
16776961 [0xFFFF01] Archive (inactive)
ACC_04 keine Kommunikation
Status bits: 1
Priority: 2
Frequency: 1
Odometer: 75913 km
Status: Confirmed
16776962 [0xFFFF02] Archive (inactive)
Airbag_01 keine Kommunikation
Airbag_01 communication error can_error_timeout
Status bits: 1
Priority: 2
Frequency: 1
Odometer: 75913 km
Date, time: 2025.09.23 22:28:54
Status: Confirmed
16776964 [0xFFFF04] Archive (inactive)
BCM_01 keine Kommunikation
Klemmen_Status_01 communication error can_error_timeout
Status bits: 1
Priority: 6
Frequency: 1
Odometer: 75913 km
Status: Confirmed
16776968 [0xFFFF08] Archive (inactive)
ESP_24 keine Kommunikation
ESP_24 communication error can_error_timeout
Status bits: 1
Priority: 2
Frequency: 1
Odometer: 75913 km
Date, time: 2025.09.23 22:28:57
Status: Confirmed
16776970 [0xFFFF0A] Archive (inactive)
LWR_AFS_01 keine Kommunikation
LWR_AFS_01 communication error can_error_timeout
Status bits: 1
Priority: 6
Frequency: 1
Odometer: 75913 km
Status: Confirmed
16776971 [0xFFFF0B] Archive (inactive)
Motor_04 keine Kommunikation
Motor_04 communication error can_error_timeout
Motor keine Kommunikation
Status bits: 1
Priority: 6
Frequency: 1
Odometer: 75913 km
Status: Confirmed
16776973 [0xFFFF0D] Archive (inactive)
RKA_01 keine Kommunikation
RKA_01 communication error can_error_timeout
Status bits: 1
Priority: 6
Frequency: 1
Odometer: 75913 km
Date, time: 2025.09.23 22:29:01
Status: Confirmed
16776978 [0xFFFF12] Archive (inactive)
LH_EPS_01 keine Kommunikation
LH_EPS_01 communication error can_error_timeout
Status bits: 1
Priority: 2
Frequency: 1
Odometer: 75913 km
Status: Confirmed
16776980 [0xFFFF14] Archive (inactive)
PLA_Status keine Kommunikation
PLA_Status_01 communication error can_error_timeout
PLA_Status_01 keine Kommunikation
Status bits: 1
Priority: 6
Frequency: 1
Odometer: 75913 km
Status: Confirmed
16776983 [0xFFFF17] Archive (inactive)
WBA_03 keine Kommunikation
Status bits: 1
Priority: 6
Frequency: 1
Odometer: 75913 km
Date, time: 2025.09.23 22:28:58
Status: Confirmed
16776988 [0xFFFF1C] Archive (inactive)
TSK_07 keine Kommunikation
Status bits: 1
Priority: 2
Frequency: 1
Odometer: 75913 km
Status: Confirmed
16776993 [0xFFFF21] Archive (inactive)
ESP_21 keine Kommunikation
Status bits: 1
Priority: 2
Frequency: 1
Odometer: 75913 km
Status: Confirmed
2B. Steering column lock (UDS)2B. Steering column lock (UDS)
DTCs: 2
12665088 [0xC14100] Archive (inactive)
Timeout Message Klemmen_Status_01
Status bits: 1
Priority: 6
Frequency: 1
Odometer: 75913 km
Engine RPM: 290 rpm
Calculated engine load value: 0.00 %
Vehicle speed: 160 km/h
Engine coolant temperature: -39 ℃
Engine oil temperature: -33 ℃
Barometric pressure: 14 kPa
Klemme 30 voltage: 0
Status: Confirmed
12665089 [0xC14101] Archive (inactive)
Timeout Message ZV_02
Status bits: 1
Priority: 6
Frequency: 1
Odometer: 75913 km
Engine RPM: 290 rpm
Status: Confirmed
42. Driver door electronic equipment
No DTC found.
44. Power steering
No DTC found.
52. Front passenger door electronics
No DTC found.
55. Headlights corrector55. Headlights corrector
DTCs: 1
9574144 [0x921700] Archive (inactive)
B121700: Left low beam headlamp bulb
Lampe fuer Abblendlicht Scheinwerfer links
Status bits: 1
Priority: 6
Frequency: 11
Odometer: 75903 km
Date, time: 2025.09.23 00:15:14
Status: Confirmed
5F. Electronic Information System 1
No DTC found.
6D. Tailgate/Boot lid6D. Tailgate/Boot lid
DTCs: 1
00047 [0x00002F] Archive (inactive)
U111100: Function limitation due to missing message
Funktionseinschränkung wegen fehlender Botschaft
B11DD12: Pinch protection strip 3, Short circuit to B
Pinch protection strip 3 Short circuit to B
Status bits: 1
Priority: 6
Frequency: 1
Odometer: 75913 km
Status: Confirmed
76. Parking assistant76. Parking assistant
DTCs: 1
Status bits: 1
Priority: 6
Frequency: 1
Odometer: 75902 km
Status: Confirmed
A9. Structure-Borne Sound Actuator / Exhaust flaps (UDS)
No DTC found.
Edited by Bagley
Check the fuse's in the engine compartment
Checked , now the sun roof isn't functioning .
There a big in the system
Getting tech to use vcd to check.
Fixed sun roof with a fuse.
The lights and rear brake all still not working
Head lamp maybe a controller module
Would anyone be able to support fixing this issue
My head lamp left
Right hand driving light strip front
Right hand rear brake light
All not working with error lights still
When I flick the light switch dial these errors come up on the screen.
Does any one know this part , can help me find one , and or tell me what AE means on end of part numbers.
what does letters mean on end of a part number 5QO 937 086 ae
This is the BCM = This unit Managed the Light and Other things.
AE ist the Index of unit.
It's important that it's the same functional group. There are basically three versions: Low / Mid(+) and High. You always have to install the same or higher-quality version.
If I find a part with out AE is this still able to work
And does anyone have a parts place in Melbourne that would have these , or can I fix it
