LED replacement
Has anyone had to replace an LED indicator on a 22 plate Karoq?
I have been informed that the whole headlight unit has to be replaced just for the LED indicator at a cost of £1200.
The LED Indikator realy dont Work?
On board computer shows the fault and the LED front offside indicator is not working
But the daytime running light works?
Yes, all the other bulbs work,
The garage said they dispose of the whole unit so I shall ask for the bulbs (these can be replaced easily and cheaply).
Warrenty or you have To Pay?
3 year warranty had expired and we had not extended it.
The headlamp bulbs can be changed independently but the LED indicators are not - hence the whole unit needing replacing.
Which Type of Headlights you have?
PHOTO?
Car is at the dealer, Karoq 2022 Drive TDI SCR
Glad my Kamiq has normal indicator bulbs!
If this is the version of the headlights where daytime running lights and indicators are in one, there is a control unit and a repair cover
Cairns, I shall check but it does say LED on the unit and both the Skoda dealer andmy local mechanic say it is the whole unit.
