EPC fault - Skoda fabia 2016 1.2
Hi everyone,
I was recently trying to clear some fault codes, including airbags and ABS. After clearing the ABS fault, the EPC light came on, so I ran a VCDS scan, and the attached errors appeared.
Any help with these would be greatly appreciated — I’m thinking they might need recoding, but I could be wrong.
Thanks in advance
Hi, welcome.
It may depend on what caused the codes in the first place and/or what you were dong on or to the car before you needed to clear the codes.
If the battery had got very low and or you have just changed it then I'd try try deleting the codes again, starting the car, turn the headlights, blower and air-con on, then turn the steering full lock left and right for high electrical load, then turn them off and go for a reasonable length drive and then see if the EPC remains or comes back on. This assume the battery is at a reasonable state of charge and heath.
For info, for photos generally you get more information in the shot if you take them landscape (and not portrait).
Others will know more and have different advice.
For VCVDS diagnostics there is another forum on Briskoda if you need more help and advice. - 'Diagnostics & VCDS' forum - https://www.briskoda.net/forums/forum/23-diagnostics-amp-vcds/
HTH.
Edited by nta16
