Skoda Scala with Acc Vcds Auto scan
I am in the process of retrofitting ACC on my 2019 skoda scala. Part of the retrofit is a new steering electronics control unit that connects to canbus. I am having some trouble with the coding, so if you happen to have a Skoda Scala with acc and a vcds on your hand, I would greatly appreciate an auto-scan.
Share a Autoscan from your Car.
Which Hardware you have installed?
I have changed the steering electronic unit to 5Q0953569B and the stalks to 5Q0953521LA from 6RA959653A and 2Q1953507AE. The wiring loom was remade and the steering electronics united was connected to canbus. Besides ticking the address 16 in the can gateway installation list and playing around with the coding of 16, I haven’t done anything else. My problem now is that the stalks don’t work, the airbag doesn’t work, only the steering wheel buttons work.
Auto-scan
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 25.3.0.3 (x64)  HEX-V2 CB: 0.4660.4
Data version: 20250301 DS365.0
www.Ross-Tech.com
VIN: TMBEP9NW8L3043863   License Plate:
Chassis Type: NW-SK27 (2Q0)
Scan: 01 03 08 09 10 13 15 16 17 19 44 5F 75 A5
VIN: TMBEP9NW8L3043863   Mileage: 86700km-53872miles
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
10-Park/Steer Assist -- Status: OK 0000
13-Auto Dist. Reg -- Status: OK 0000
15-Airbags -- Status: Malfunction 0010
16-Steering wheel -- Status: Malfunction 0010
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
5F-Information Electr. -- Status: OK 0000
75-Telematics -- Status: Malfunction 0010
A5-Frt Sens. Drv. Assist -- Status: OK 0000
Address 01: Engine (J623-DKLA)       Labels:. 04E-907-309-V1.clb
   Part No SW: 04C 906 025 AP    HW: 04C 907 309 BP
   Component: R3 1.0l TFS   H20 7056
   Revision: DGH20000    CVN: D89F6107
   Coding: 0111003223241D080000
   Shop #: WSC 31000 790 00059
   ASAM Dataset: EV_ECM10TFS01104C906025AP 003001
   ROD: EV_ECM10TFS01104C906025AK_003_SK27.rod
   VCID: 6E85CEA51014FBAA6DC-803A
   VINID: 91D4958097A721C0C01032060C543048A7
1 Fault Found
18875 - Cruise Control Switch (E45)
          P0568 00 [00100111] - Implausible Signal
          Not Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Mileage: 86700 km
                    Date: 2025.09.28
                    Time: 02:38:08
                    Engine speed: 0.00 /min
                    Normed load value: 0.0 %
                    Vehicle speed: 0 km/h
                    Coolant temperature: 24 °C
                    Intake air temperature: 19 °C
                    Ambient air pressure: 1000 mbar
                    Voltage terminal 30: 12.200 V
                    Unlearning counter according OBD: 40
                    Acceleration: 0.000 m/s²
                    Cruise Control System (CCS): status-Bits 0-7: 7
                    Cruise_control_shutoff_conditions_irreversible-Bits 0-7: 0
                    Cruise_control_shutoff_conditions_irreversible-Bits 0-7: 1
                    Cruise control system: temporary deactivation-Bits 0-7: 255
                    Accelerator pedal travel: 0.00 %
                    Cruise control switch actuation-Bits 0-7: 0
                    Cruise control switch actuation-Bits 0-7: 32
Readiness: 1110 0001
Address 03: ABS Brakes (J104)       Labels: None
   Part No SW: 2Q0 614 517 AL    HW: 2Q0 614 517 N
   Component: ESC_base_vFGS H23 0260
   Serial number: 08509333191014
   Coding: 81108C64194581B03104981C24DD62A64962AD06224A24584C541255452446659246B5604452241A322A48AAA249D74B3D92EBD2BC242424242424
   Shop #: WSC 31000 790 00079
   ASAM Dataset: EV_Brake1BOSCHESPMQBA0 005001
   ROD: EV_Brake1BOSCHESPMQBA0_005_SK27.rod
   VCID: 78A9E8FD6250B51AB70-802C
No fault code found.
Address 08: Auto HVAC (J255)       Labels:* Redir Fail!
   Part No SW: 654 907 044 B    HW: 654 907 044 B
   Component: Climatronic   H05 0703
   Coding: 111000000800010001100400524401051010000000000000000000000000
   ASAM Dataset: EV_ACClimaBHBMQBA0 004023
   ROD: EV_ACClimaBHBMQBA0.rod
   VCID: 196FCD79B91A4C1268E-804C
Address 09: Cent. Elect. (J519)       Labels:. 5Q0-937-08X-V2.clb
   Part No SW: 2Q0 937 089 B    HW: 2Q0 937 089
   Component: BCM A0 Std    H10 0934
   Serial number: 01101927100578 Dataset Number: V03935311EU 0001
   Shop #: WSC 00000 000 00000
   ASAM Dataset: EV_BCMA0 205001
   ROD: EV_BCMA0_205_VW27.rod
   VCID: 392F2DF919DA6C1288E-806C
   Rain/Light Recognition Sensor:
   Subsystem 1 - Part No SW: 81A 955 555 A    HW: 81A 955 555
   Component: G397_RLFSS  H06 0002
   Serial number: 23719679X81A955555A0
   Coding: 80005D
   Driver door control module:
   Subsystem 2 - Part No SW: 2Q1 959 405     HW: 2Q1 959 163
   Component: FHSG_DRV  002 0005
   Serial number: 00000000000034049319
   Coding: 010208
   Front passenger door control module:
   Subsystem 3 - Part No SW: 2Q1 959 406     HW: 2Q1 959 164
   Component: FHSG_PSG  002 0005
   Serial number: 00000000000034475654
   Coding: 190208
1 Fault Found
227080 - Turn Signal Switch
          B1144 29 [00001001] - Signal Implausible
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 228
                    Mileage: 86700 km
                    Date: 2025.09.28
                    Time: 02:38:10
                    Zusaetzliche Umgebungsdaten-Terminal 15 status: On
                    Zusaetzliche Umgebungsdaten-Terminal 50 status: OFF
                    Zusaetzliche Umgebungsdaten-Low beam: Not operated
                    Zusaetzliche Umgebungsdaten-OFF: Not operated
                    Zusaetzliche Umgebungsdaten-Outside temperature: -50.0 °C
                    Zusaetzliche Umgebungsdaten-Automatic high beam assist: Not operated
                    Zusaetzliche Umgebungsdaten-Position lamps: Not operated
                    Zusaetzliche Umgebungsdaten-Parking light left: Not operated
                    Zusaetzliche Umgebungsdaten-Parking light right: Not operated
                    Zusaetzliche Umgebungsdaten-CAN-Bus_aktiv: On
                    Zusaetzliche Umgebungsdaten-last wakeup: keine Stoerschutzursache
                    Zusaetzliche Umgebungsdaten-Status Bremslichtschalter (CAN): OFF
                    Zusaetzliche Umgebungsdaten-Status Bremslichtschalter (HW): OFF
                    Zusaetzliche Umgebungsdaten-voltage measurement: 12.3 V
Address 10: Park/Steer Assist (J446)       Labels:* None
   Part No SW: 5QA 919 283 E    HW: 5QA 919 283
   Component: PDC 4 Kanal   H08 0061
   Serial number: 000150059319282 Dataset Number: V03935308KL 0001
   Coding: 0601150001
   ASAM Dataset: EV_EPHVA14AU3700000 009044
   ROD: EV_EPHVA14AU3700000_009_VW27.rod
   VCID: 4CC1642D4648E9BA238-8018
Address 13: Auto Dist. Reg (J428)       Labels:| 2Q0-907-572.clb
   Part No SW: 2Q0 907 572 R    HW: 2Q0 907 572 B
   Component: ACCCONTIMQB   H03 0372
   Dataset Number: V03935305JH 0001
   Coding: 2A04600100FF8748949C810500508700000000000000000004
   ASAM Dataset: EV_ACCMRRCONTIVW376 003016
   ROD: EV_ACCMRRCONTIVW376_003_VW27.rod
   VCID: 43D34F116B1626C2D22-8016
Address 15: Airbags (J234)       Labels:| 2Q0-959-655.clb
   Part No SW: 2Q0 959 655 AM    HW: 2Q0 959 655 AM
   Component: VW22Airbag    012 0351
   Revision: --------    Dataset Number: V03935307FU 0001
   Coding: 98FCC0C0000000005C5400CF000840A80065
   ASAM Dataset: EV_AirbaVW22BPAVW27X 001020
   ROD: EV_AirbaVW22BPAVW27X.rod
   VCID: 0849983D12B0C59AC70-805C
   Left seat belt tensioner:
   Subsystem 1 - Part No SW: 654 980 945     HW: 654 980 945
   Component: BeltPretRevFL  004 0051
   Serial number: 278A-001614101900340
   Coding: 303531
   Right seat belt tensioner:
   Subsystem 2 - Part No SW: 654 980 946     HW: 654 980 946
   Component: BeltPretRevFR  004 0051
   Serial number: 278A-001614101900601
   Coding: 303531
   Crash sensor for side airbag: driver side:
   Subsystem 3 - Part No SW: -----------    HW: 442 061 009 19
   Component: SideSensor_Df  1E2 0887
   Serial number: 3577Y50C531E245521F1
   Coding: 2D2D2D
   Crash sensor for side airbag: passenger side:
   Subsystem 4 - Part No SW: -----------    HW: 442 061 109 19
   Component: SideSensor_Pf  1E2 0887
   Serial number: 3587Y50C931E2451320W
   Coding: 2D2D2D
   Rear Side Airbag Crash Sensor (on driver's side):
   Subsystem 5 - Part No SW: -----------    HW: 442 0B1 809 19
   Component: SideSensor_Dr  1C7 0148
   Serial number: 35177809D33DB1C3619T
   Coding: 2D2D2D
   Passenger side rear thorax airbag crash sensor:
   Subsystem 6 - Part No SW: -----------    HW: 442 0B1 809 19
   Component: SideSensor_Pr  1C7 0148
   Serial number: 3527780A333DB1C4E3AX
   Coding: 2D2D2D
   Crash sensor for front airbag: driver side:
   Subsystem 7 - Part No SW: -----------    HW: 442 132 208 19
   Component: FrontSensor_D  290 118A
   Serial number: 355AG11A130CACA214AU
   Coding: 2D2D2D
1 Fault Found
9437211 - Igniter for Driver's Airbag
          B1000 1B [10001001] - Resistance Too High
          MIL ON - Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Mileage: 86700 km
                    Date: 2025.09.28
                    Time: 02:38:10
Address 16: Steering wheel (J524)       Labels:* Redir Fail!
   Part No SW: 5Q0 953 521 LA    HW: 5Q0 953 569 B
   Component: Lenks.Modul   100 0245
   Revision: FF036036    Serial number: 20171214500935 Dataset Number: V03935261HE 0001
   Coding: 6404
   Shop #: WSC 73430 790 12345
   ASAM Dataset: EV_SMLSVALEOMQBLRH 001007
   ROD: EV_SMLSVALEOMQBLRH.rod
   VCID: 7CA1F4ED5668993AD38-8028
1 Fault Found
291104 - Temperature Sensor for Heated Steering Wheel
          B1455 01 [00001001] - Electrical Failure
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 228
                    Mileage: 86700 km
                    Date: 2025.09.28
                    Time: 02:38:08
                    Ubat 30 Voltage: 12.30 V
                    Internal error state: 0
                    LIN_Temp: 254
                    Isense: 0
                    Max.Leistung: 110
                    PWM: 0
                    Offset: 10
                    Slope: 133
                    kp: 18
                    OUT: 50
                    Temperatur Statisch: 30
                    p_t_soll_0: 34.00 °C
                    p_t_soll_1: 39.00 °C
                    p_t_soll_2: 44.00 °C
Address 17: Instruments (J285)       Labels:* None-SRI3
   Part No SW: 654 920 740 A    HW: 654 920 740 A
   Component: KOMBI         204 3354
   Coding: 07A502026180000801883E031001000800000000
   Shop #: WSC 03424 295 57173
   ASAM Dataset: EV_DashBoardMMMQBA0 001022
   ROD: EV_DashBoardMMMQBA0_VW27.rod
   VCID: 1675C6454804636A45C-8042
Address 19: CAN Gateway (J533)       Labels:* Redir Fail!
   Part No SW: 2Q0 909 901 C    HW: 2Q0 937 089
   Component: GW MQB A0     H10 0934
   Serial number: 01101927100578 Dataset Number: V03935313JC 0001
   Coding: 030100042F0A570001100244000F00010001070000000000000000000000
   GVL: 01543C0000000000408080008000480000000000000000000000000000000000
   ASAM Dataset: EV_GatewA0 013026
   ROD: EV_GatewA0_VW27.rod
   VCID: 323D1AD5C4AC9F4A494-8066
   Generator:
   Component: 2-01-14-01-04
   Multifunction steering wheel control module:
   Subsystem 2 - Part No SW: 3V0 919 719 E    HW: 3V0 919 719 E
   Component: E221__MFL-PR6  H03 0180
   Serial number: 000000000C1195091019
   Battery Monitoring Control Module:
   Subsystem 3 - Part No SW: 2Q0 915 181 B    HW: 2Q0 915 181 B
   Component: J367-BDMBOSCH  H02 2012
   Serial number: 1001D5AD
Address 44: Steering Assist (J792)       Labels:* None
   Part No SW: 2Q1 909 144 M    HW: 2Q1 909 144 F
   Component: TRW_G4L_MQBA0 611 6041
   Serial number: 1482646CB2K2923 Dataset Number: V03935307NF 0001
   Coding: 010000000100000001010201010001000000010101
   ASAM Dataset: EV_SteerAssisTRWG4LMQBA0 011016
   ROD: EV_SteerAssisTRWG4LMQBA0.rod
   VCID: 3C2134ED16E8593A938-8068
Address 5F: Information Electr. (J794)       Labels:* None
   Part No SW: 654 035 871 A    HW: 654 035 871 A
   Component: MU-E--ER      040 1800
   Serial number: CVRV49XBAED0003 Dataset Number: V03935341VF 0001
   Coding: 33703000000000000000000000000000000000000000000000
   ASAM Dataset: EV_MUEI 001007
   ROD: EV_MUEI_VW27.rod
   VCID: 1869C87D4210551A570-804C
Address 75: Telematics (J949)       Labels:* None
   Part No SW: 5WA 035 282 C    HW: 5WA 035 282
   Component: OCUGen3Low    H14 0200
   Serial number: 0000000906NVWP2 Dataset Number: V03935337QC 0001
   Coding: 03370310196808808005460160010607
   ASAM Dataset: EV_OCUGen3Low 003008
   ROD: EV_OCUGen3Low.rod
   VCID: 44D14C0D6E1821FAEB8-8010
1 Fault Found
12866049 - Databus
          U1123 00 [00001001] - Received Error Message
          [Airbag: Error value received]
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 40
                    Mileage: 86700 km
                    Date: 2025.09.28
                    Time: 02:38:10
                    Voltage terminal 30: 12.2 V
Address A5: Frt Sens. Drv. Assist (R242)       Labels:* None
   Part No SW: 3Q0 980 654 R    HW: 3Q0 980 654 A
   Component: MQB_B_MFK     H12 0460
   Serial number: 15101915P23993 Dataset Number: V03935305SP 0001
   Coding: 0202070000000401002200448156440084000E20002000
   ASAM Dataset: EV_MFKBoschMQBB 002041
   ROD: EV_MFKBoschMQBB_002.rod
   VCID: 46D55605582413EAF5C-8012
End----------(Elapsed Time: 00:52, VBatt start/end: 12.1V/12.0V)-----------
------------------------------5 Faults Found-------------------------------
Why are you installing something that wasn't previously registered in the CAN gateway? Let me guess, a 5Q1 clock spring was installed before?
I strongly recommend that you do not move the vehicle and dismantle it immediately
Edited by Cairus
Yes and no, I am installing the necessity clockspring for acc, but it is a 5q0 clockspring. You can find all the part numbers before the autoscan
Once again. If there was a 5Q1 clock spring before, dismantle it immediately. A 5Q1 spring is a LIN participant of the BCM!!! Not a participant of the CAN!!!!
Once again the previous clockspring is 6RA959653A. Not 5Q1. The necessity modifications were made to the wiring loom to be up to spec as if my car was fitted with acc from the factory. Since the new clockspring is can based, naturally i connected it to the canbus, my problem is that I can’t code the 09 and 19 correctly to stop looking for signals from the previous wires and look at the can bus
This dont Work
Why is that?
Because your entire system is built on a clock spring in the LIN. Why don't you use the right parts?
I am not sure that I agree with you. On drive2 ru you can find other people with the same setup for the can gateway and bcm, the only difference is that their cars came with can bus already there. But if I am indeed wrong, what would be the correct parts?
Also, the new clockspring has a lin bus wire too
If you know better, why doesn't it work? Of course it has a LIN connection to the gateway for the multifunctional steering wheel. The vehicle has more than one LIN connection.
Because i am having trouble with the coding, since i am asking if someone is willing to share theirs autoscan. I am not saying that I know everything, but I know for a fact the car is compatible with 5q0. Does it need other modifications than that? I don’t know
Good Luck
Thanks, btw checkout 7zap, you can find all the parts for a car. Hint: 5q0 is listed as a skoda scala part :)
You don't want to understand. Thanks, I have the Skoda database directly.
I've spent a lot of time researching how to install ACC on my 2022 Kamiq. The Kamiq and the Scala share the same base. However, even though I retrofitted the ring and the stalks, activating ACC is a swap function and therefore requires a direct connection to the VW server.
There are also many other wiring harness modifications to be made to transmit information between the ECUs (DSG, front camera, etc.). However, you're right, the original stalks are connected to the vehicle via LIN, while the new ones go through the J500, which is the steering ECU you installed. You therefore need to declare somewhere that the information no longer comes from LIN but from CAN. And you also need to declare the new ECU in module 19.
Have you made any progress on your retrofit?
You know that the Scala and Kamiq without ECU 16 also have ACC? However, you have a BCM that has the gateway integrated, probably mid-version.
I think this is the Problem
Edited by Cairus
Thanks for the reply, the swap function can be activated without vw servers with an exploit, I won’t go in details here because it is outside of the scope. I managed to get my hands on an autoscan from a scala fitted with acc. The problem is that the car has a bcm and an external gateway, my car has only the the bcm with integrated gateway. A russian guy claims that it is still possible to use my bcm, i have messaged him and i am waiting for a reply. You highlighted my exact problem, where do i tell the bcm to stop looking for the lin signal and look for can. If you want, you can message me to compare notes, maybe we figure it put :)
So far, I haven’t seen one with that build, but if you want to elaborate, i am still open for a discussion
https://forums.ross-tech.com/index.php?threads/42131/
How do you know it has acc? That is how my car’s auto scan looks, but I only have front assist?
Also, you said you said you retrofitted the ring and the stalks, did you manage to get them working?
I haven't retrofited yet this function on my Kamiq, but just searching a lot of information.
For my side, I have a separate gateway module because I have the High BCM
