LED bulb for low beam headlights
Hy,
I would like to ask for your help. I have a 2016 Skoda Octavia. I would like to replace the low beam headlight bulb with an LED bulb. My question is: what do I need to change in VCDS? Is it enough to disable the cold bulb diagnostics? Can I disable only the cold bulb diagnostics for the low beam headlights? LED bulbs are legal in Hungary. LED type: NIGHT BREAKER LED START
Could you tell me which parameter I need to change in VCDS? I know how to use VCDS if I know which parameter to modify.
Thank you!
Osram Light?
3 minutes ago, Cairus said:
Osram Light?
Yes. I found some information. My car does not have "cold start diagnostics." It has a "Leuchte-sets"
Control unit 09, also called BCM, adjustment, then take the appropriate light
