Kessy locking keys in car
Good point. I tried my own car again this morning: unlocked it, put the key on the passenger seat and stood and watched. Six minutes later nothing had happened. So it’s definitely inconsistent, whatever it’s supposed to be doing.
6 hours ago, SkOmk4 said:
...User Manual?
Let's not forget that leaving the key inside the car while washing the car, is a (widely used) way to avoid the car locking and unlocking + folding/unfolding mirrors.
Well I've managed to lock my key in my car AND the boot on separate occasions, and can confirm the above is BS, both times I had to find a way home to get my spare key to unlock 😠
With the key on the passenger seat it would likely be detected by the sensor (near the cup holders I believe).
What would happen if the key were left on the back seat or in the boot?
I’ve not experienced any issues or keys locked (yet) but when I get a chance will try a few tests too.
Both times my key was in a jacket pocket, could be why it wasn't detected, although I'd left it in such a way on countless occasions prior with no issues... Definitely a head scratcher
I do not know where the antennas for the kessy are located in our cars, I had to work time ago on an A8 D3 which had problems and I found four outside antennas, two each behind the bumpers, and the other two at the sides - around the B-pillar.
This in addition to the handle buttons.
If a similar setup is used, there is no way a key left in the boot would not be detected by the antenna there.
And no, if it is ramdom you can open/close a zillion times, and will not do it, just to drive you mad ...🙃
Yes. When my original problem occurred a couple of weeks ago, the key was actually in the cup holder, so certainly should have been detected.
