Manual Gearbox oil change
Hi everyone,
I just bought a used Octavia mk4 1.5 TSI. Whilst I am looking at changing oils, I can find the engine oil sump plug, but I cannot spot where are the gearbox drain and fill plugs. Can anyone please help. Thank you
If you have this gearbox you fill oil with hole from this switch
Yes, there is a screw look like the purple drain screw in the picture, thank you very much!
Here is photo from gearbox fill switch
