Lurches on left-hand bends?!
Not sure if this is linked to me fitting new shocks (see https://www.briskoda.net/forums/topic/489523-octavia-scout-mk3-rear-suspension/ for details – did go stiffer for towing) or wheel alignment or something weird going on with the Haldex but my Scout has a mildly disconcerting bounce/lurch at times. Particularly when on left hand curves. Does anyone know what I should be checking? The garage have checked and told me everything is where it should be and all bolts etc torque'd. Have I just upset the handling? But if so, why especially when steering left? Andy advice/suggestions welcome. Thanks, Jonathan [2015 Scout]
Check the tracking and check the suspension. IMHO Octavia's are known for breaking springs (I've had several go on me). Check the springs and the dampers. Please note that the Scout suspension is unique so make sure you have the correct parts for any that you replace.
I think by fitting different springs (to what was there) I've upset things. Just not sure why it's only (most noticeable) when on left hand bends! Thanks!
Sounds like you've installed the wrong springs....
  • 6 months later...
Still doing it. Found someone on facebook saying his does it too. Anti-roll bars? Drop links? I'm going to get the garage tocheck all the springs/shocks etc. Anyone else experienced it? Thanks.
Yeah... that's not a 'known' or 'common' issue - that's more of a 'this is a dangerous issue, get to the bottom of it immediately' rather than seven months down the line.
You can fit all manner of springs, coilovers and the like, and absolutely none will cause the car to lurch to one side. An instability is a problem, but an imbalanced instability points to something that is pretty wrong.
Does the car sit evenly - are the springs seated properly? Are the top mounts done correctly? Are the drop links fitted properly, with no play? Are the ARB bushes all good - no twisting or deformation as a result of incorrect install?
Something is not right on that side.
