Electric windows
Mk3 Greenline. Driver window one touch not working, have to hold the switch to fully open or close, all others are fine. Also windows will not open or shut on the key fob?
Try holding switch down for 5-10secs once window is fully up and also fully down. I changed battery in my mk2 octy and lost one touch window control until I reset windows. They wouldnt work from key fob either until I did the process of holding window switch
Alasdair
Alasdair1, thanks for that but......
Ignition on or off?
Engine on or off?
I know I sound thick but tried both so what am I doing wrong please
As long as the windows work I dont think it matters but try both again with ignition on and also engine running. This came from Ai but for once its right. I normally bypass whatever google Ai comes up with.
This procedure recalibrates the window's upper and lower limits.
  1. Close Window: Turn the ignition on. Roll the window all the way up using the switch, but keep holding the switch up for an extra 5 seconds after it's fully closed.
  2. Open Window: Roll the window all the way down, and keep holding the switch down for another 5 seconds after it's fully open.
  3. Test: Try the one-touch function. It should now work.
If this doesnt work it may be something else thats the problem. I would hold switch for 10 secs to be sure. Worked for me so hope it works for you
Alasdair
Thanks very much, I will try again tomorrow.
All working now, thanks.
