MK1 Octavia Spider 17" Fitting
Hello Troops,
Just a quick one - does anyone know if a pair of Spider 17" alloys would fit a NJ3 Fabia Monte Carlo?
Have a look here and see what it sez but double-check and cross reference any information you get from any source including manufacturers. - https://www.wheel-size.com/size/skoda/
Good luck.
PCD and CB are the same. Offset is 8mm difference so think should be ok for car +/- 10mm is the rule I go by but only real way is to check by trying in case it rubs at full lock or when hitting speedbumps . Both have 17" wheels as options.
Alasdair
