Brake warning light not turning off after front pads changed.
Hi, to save money I decided to change the front pads on my Kodiaq 2023 4x4 (200bhp) It wasn’t that hard and I used the recommended pads from Bosch. All fitted in nice and the cable had a solid click in. I read that you could turn the ignition on and wait a few minutes for the car to self diagnose and reset. However the light will not go out. So my question is a follows, can I but a obd scanner and do it myself or do I need to take to Skoda? Thanks in advance.
Hi there, most OBD scanners will be able to do that, even cheap (10 EUR) ones.
I'd say drive it a bit see if it goes away in a week, if not, check the web and product description for an OBD that can remove error codes As long as the brakes work, no worries about it.
