Infotainment usb problems
Hi !
I have Mk3 -16 Octavia 2.0 TDI 4X4 VRS, with bolero system, i have started to have issues with apple carplay, it has worked almost perfectly to this moment.
There has been times that i have done soft reset for the radio by pressing the power button for 10 seconds and that has fixed the problem. After winter and -30C arrived problems started, i dont know if this is related to that.
When i cold start the vehicle and plug my phone in to it it can work fine for 5-20minutes, then display freezes and carplay disconnects, after that it wont connect again, bluetooth and charging works fine.
I have tried different cables and phones, same problems with everything, i am starting to think that the problem is the usb socket. Does anyone have guide to how to change this ? And am i correct that i have to take the screen off and also air condition panel ? If i take the screen off does it need some kind off code that when i plug it again ?
Thx for your help !
Br
Petri
What firmware are you running on your system? Can you Press and HOLD MENU and then go to Software Version and take a photo for us, then we can advise. It will be an issue between Apple Carplay and the version of software on your MIB system.
Is this correct ?
