Rear door will not open
Hi all,
I know this has been covered numerous times, but I cannot look for the topic, I am away from home so no computer access.
The rear door has first stage released but when i press the button on the door I can hear the second stage release actuating and then cancelling.
What di I need to do to open the door and any links to solutions on here please
Have you tried double pressing the "open car" button on the fob?
Tried that, no joy!
However had a poke around in the hole in the back card and yes opened the door, checked its operation and it worked, Have squirted some ptfe lube into it, it now works fine!
Maybe caused by carrying 2 x new tyres in the boot area which might have put pressure on the door card and hence a little strain on the lock mechanism thus causing my problem!!
