Rear drum backplates..
Hi..
Does anyone know of a supplier of the above drum backplates?
Can't find any online, even good used ones would be ok, especially a n/s plate as mine is rusted out.
Thanks.. I'll keep searching, maybe a trip to a breakers, although getting one off is an epic in itself. Had to destroy the bearing and use an angle grinder and chisel to remove the bearing inner off the stub axle.
If you go to the link above and check fitment it gives you a fair list of vw,seat and skoda cars it fits. Might help widen down your search at breakers etc.
Alasdair
