Radiator fans
2010 diesel yeti
Just looking at the 2 radiator fans. If they both run in the same direction, one seems to pull air through the rad and the other pushes it forwards. Going by the shape of the blades. LH spins CW front the front. If the RH spins CW from the front then it will pull air towards the radiator.
  • Sponsor
If you switch on the A/C with bonnet open you can probably observe directly which way they spin, can't you?
Yep.
Different blade profiles and they spin opposite directions.
LH CW
RH CCW
From front
