My Mk1 Fabia SE
Anyone on here got some information about my SE, i noticed above the driver side headlight that there was a sticker previously there of the website just wondering if anyone can tell me anything about it, cars been great so far but needs a new camshaft so upgrading to the SDI
Welcome to the site.
What number is on your your seats? There were only 1000 of the SE as a run-out model, and each was individually numbered on the seats
i am very aware haha, it’s number 165 was just wondering if anyone on the web has had the car before me as there was the sticker outline i mentioned above the headlight and then i also discovered one above my centre mirror that i’ve pulled off
You'll find it on this thread.
- 165 Jennny (Bought Used. Motorpoint, Burnley, 21st October 07)
cheers mate, my plates do have motor point burnley on but the plates aren’t the same
may also be a case that i have the seats from said ‘165’ and it’s not actually the correct number
I don't fully understand your post. How can going from a Fabia vRS PD130 TDI to a non-turbo SDI (64 Bhp) be an upgrade?
He's talking about fitting the camshaft from an SDI. It's a reasonably common upgrade as the lobes have a slightly longer lift.
S-Tune
No image preview
1.9TDI PD SDI Camshaft Kit
S-Tune 1.9 TDI Billet Steel Camshaft Kit (Mild Upgrade) Our camshafts are produced to the highest quality specification of any billet steel camshaft currently for sale. Using the larger SDI Camshaft h
If your doing the cams you jight as well fit larger injectors and pd150 head bolts at the same time
