Windshield from the VIN number - help needed
Can anybody help to define number of windshield from a VIN number?
<Removed>
Thank you
Please use do not post your VIN or reg number on the public forums, as data scraping may use this information for vehicle cloning or other activities. Only send this information via the PM (Private Messaging) function to trusted members. If the PM function is not yet available to you, tagging the member and asking them to start a conversation will work.
Briskoda Admin
Evening,
I presume you trying to figure out the part number of the specific windscreen?
6 minutes ago, mac11irl said:
Evening,
Yes, you are right
Surely there’s a product number on it somewhere like the side windows?
@Cairus can you please help? I have checked the windscreen from VIN number with @Breezy_Pete and it showed 3V0 845 011 AN NVB.
Is that number correct for heated screen with UV filter, acoustic for 2q0 camera, rain/twilight sensor?
I want to retrofit it to my car with normal windscreen - S3FL, 2021, camera 2q0, rain/twilight sensor.
Thank you.
Why do they need me when you have contact with @Breezy_Pete ?
He advised to contact with you as PR code is 4GW Heat insulating windshield. No info about heating. I came to the same number of windscreen by using ETKA, but I wanted to confirm it.
Edited by bobbest
  • Sponsor
The description of the windscreen for the provided VIN, of a car with heated windscreen is:
"Heat insulating windshield".
To me, that didn't sound like a convincing description of a heated windscreen, so I suggested that you might be able to confirm.
PR code was 4GW.
I have (paid) access to partslink24, but not always much knowledge about what I'm looking at.
According to my information, the mentioned article number should be correct.
Thank you both, the dealer confirmed abovementioned part number :-). They will install heated windscreen to my car. The rest stuff will be installed later.
