Door Umbrella
Neigbour with a Fabia Mk4 called me recently, his drivers door and the rear (right) passenger doors were partly open with what looked like a stainless steel rod jamming the two doors in their partly open/closed positions, to make a long story short, it was the door umbrella that apparently had shot out somehow or other and jammed the two doors, he had partially opened the back door to let his dog out I think and had let his own door partially open, or something like that. The car was still under warranty so the dealer sent someone out and he told me they found that the door umbrella had somehow popped out of its recess in the front door and jammed the two doors. Wonder does the 3 year warranty cover the umbrella as well!!.
I very recently got a gift of one of those Skoda (doppler) umbrellas which the wife uses, it has a release button on the handle but I can't figure out how the umbrella could open with most of it still inside the door recess even with the button pressed, seems a unusual occurance, havn't seen any reference to this behaviour before anywhere.
On most of the automatic umbrellas I've seen, the shaft extends first - which appears to have happened in this case.
My umbrella might suggest that that could only happen if something broke inside the umbrella, photo1 shows the umbrella closed, photo2 shows it after pressing the release button, it can only extend a few inches as shown with cover on and even if the cover wasnn't on, the umbrella should still, IMO, be contained by the door plastic "tube", with the handle just extended by those few inches. I show a partiall extended umbrella in the next post (no room here) where you can see two cords extending to the umbrella top, maybe one of these gave way??
Edited by Johngerard
Photo of partially extended umbrella.
Apoligies, its a year 2022 Kamiq, the neighbour didn't even know he had a door umbrella so it was never used.
He just opened his own door from the outside and when it opened he found the handle up against I presume the rear passenger door frame which was closed, he then opened this door and the handle then pushed further back. It was retrieved with no damage, the repair man handed it back in the closed position and the neighbour just put it away somewhere in his house and will give me buzz when he finds it again.
The door sleeve/tube is about 2 ins or so longer than the umbrella I have, I just inserted my umbrella far enough into the door to be able to press the release button, as expected, the handle only extended out by a few inches, this, with the umbrella cover on or off.
The Kamiq umbrella should be ~ 300mm long when closed.
My Fabia Mk4's umbrella has a Velcro band around it so that, even when the umbrella's protective fabric 'sleeve' has been removed and the release-button on the handle pressed, although the handle springs back a short distance, the Velcro band stops the umbrella opening.
(On hit-man assignments, when I have a micro-Uzi hidden under my Fabia's driver's seat, the plastic umbrella-holder in the driver's door is perfect for holding the weapon's silencer.)
I had also tried it inserted in the door tube with the fabric sleeve and the velcro band undone, same result.
It happened on my car afew weeks ago when I attempted to enter the drivers side door.I could only open the door a couple of inches as the umbrella had partially opened.Entered via the passenger door and found it extended past the b pillar.
So it could do this in an accident and stop the driver getting out.
Clearly not thought about during the design!
With my Fabia Mk4 , when the umbrella is housed in the driver's door with the umbrella's handle in its fully closed position, the handle of the umbrella does not protrude at all from the door's 'umbrella compartment'.
To reach the front of of the passenger door (and thus prevent the driver's door opening) the umbrella's handle needs to move backwards from the umbrella compartment more than 10cm/4".
Based on your experience (and the incident mentioned by Johngerard) the 'door jamming' issue clearly can occur, but - as John has said - it's hard to see how unless a serious fault develops with the umbrella's opening mechanism.
Can you replicate the problem that happened with your car's umbrella? There must be tens of thousands of Skodas that have an in-door umbrella, but the only references to it opening and jamming the door I can find online are the two in this forum's topic.
If there is a design/manufacture problem with the umbrella, Skoda should be made aware of it.
As a test, can you, remove the umbrella cover, undo the velcro strap, put the umbrella back in the door, then just pull it out just enough to press the release button, it will/should just extend a few inches which together with the few inches you pulled it out to gain access to the button, might prevent closing the door, not quite the same as the umbrella "opening" with a closed door but might throw up something.
Same test can be done with the Kamiq.
I think the umbrella is better stored under the front passenger seat seat where it used to be, not a lot can go wrong there.
Johngerard
My Fabia’a umbrella in its protective fabric cover is 28cm long and the hard-plastic storage ’tube’  that is built into the door is 29cm deep. So, when the umbrella is pushed fully into the tube, the end of the knob that has the release-button on it is about 1cm inside the tube. When the release-button is pressed, the knob only extends by 2cm.
As I said earlier, for the knob to reach the front of the rear door (and potentially jam behind it) the end of the knob must be a minimum of 10cm from the tube’s opening in the driver’s door. This means that, if the umbrella were closed up but the release-button had been accidentally pressed, the main ‘body’ of the umbrella would still have to poke out some distance from its tube before the knob contacted the rear door.
To allow the closed umbrella to be so short, its frame (shown on the attached image) and the way it folds/unfolds is complex, and the handle does not extend beyond the initial 2cm until the umbrella’s frame has opened.
I’ve tried various ways to provoke my Fabia’s umbrella into emerging from its storage tube or its handle to auto-extend, including not tidily folding up the umbrella’s fabric, then not fitting the velcro band and fabric cover, then pushing the  roughly folded 'naked' umbrella into its tube and pressing the knob’s release-button. With the umbrella closed, I also tried pulling the knob hard to see if I could get it to extend more than the initial 2cm it moves when the knob’s release-button is pressed. Nothing succeeded: even if the umbrella was far enough out of its tube for the end of the knob to touch the edge of the rear door, it still wouldn’t extend any further of its own volition.
As far as I can see, if there is no ‘mechanical’ fault with the umbrella, even if it is not in its fabric cover nor had the velcro band fitted, it will be impossible for it to open (and its handle to extend) until most of the umbrella’s body is out of the storage tube.
Edited by DerekU
Fully agree, havn't seen my neighbour since, @Mag571 might inform if her/his umbrella is still fully functional now.
This is the umbrella that "came" with the car and it does NOT have Skoda stamped on it, so...either supplied with wrong type or the dealer has bins full of umbrellas for the differenr models and they had/have the incorrect type or the original unmbrella was swapped for the this one, maybe (but unlikely) during one of its three dealer service visits, it certainly wasn't the owner as he didn't even know ii came supplied with a umbrella.
Photo1 shows the (30CM) umbrella stowed in the door, Photo2 shows it partially pulled out to access the release button, Photo3 shows that this handle WILL extend when the release button is pressed with the umbrella stowed or even if the umbrella is not in the car and the button is pressed, this is because this umbrella, when fully open does not lock in the open position, its just held open by the spring in the top (see Photo4, below), so the handle shot out, once, for whatever reason, the release button was pressed or whatever. I would strongly suggest that only OEM umbrells are used and/or ensure that to close it normally, a release button is, as normal, required to close it.
Photo 4 shows the umbrella in its open position, it only has to be pulled down to close it,
The photos in your 2nd posting above show the same umbrella as the one supplied with my Fabia Mk4, except your umbrella has a green "doppler" label on its cover and mine does not.
It's evident from this (Bulgarian) advert
https://krik.bg/products/cad-r-skoda-scala-2019-1-0-tsi-444a055c1
that this umbrella has been fitted to Skoda cars for some time and (as you've said) it has a moulded Skoda 'badge' in its handle's end. To further identify that this is a Skoda part, the umbrella has a label on its framework carrying the reference 3V0 860 353 C 9B9
And (on my umbrella) the reverse side of that label has a date-code indicating it was manufactured in September 2023 (not long before my Fabia was built).
This July 2024 article
https://psi-network.de/en/2024/07/17/sustainable-partnership-doppler-umbrellas-take-a-seat-in-skoda-cars/
included the following statement
Specially developed by doppler for the car manufacturer, the new Škoda umbrella made from environmentally friendly materials combines innovation with ecological sustainability. In the future, it will be an integral part of the equipment of many Škoda cars and reliably protect the driver and passengers from the rain.
So it may be that (since 2024) Skoda cars have had a different design of Doppler umbrella. But whether this might have the potential to 'self extend' from the door pocket is anybody's guess.
(My neighbour recently acquired a new Skoda Enyaq. I'll ask him sometime what type of umbrella it has.)
Umbrellas provided as original equipment to recent Skoda cars are manufactured exclusively by the DOPPLER company. There should be a Skoda Part Number label on the umbrella's frame and the umbrella handle's end should carry proof that it is a 'genuine' product, either using a moulded plastic Skoda 'badge' (as on my Fabia Mk4's umbrella)
or the embossed word "SKODA" as shown here.
In the latter case, I THINK that particular umbrella is only provided for higher-end Skoda models and may have Doppler's Smart-Fold or Smart-Close mechanism. But neither of the Skoda OEM umbrellas has the capability to spontaneously open/extend and jam the driver's door.
It's clear from the photo that Johngerard posted above
that the umbrella that could extend itself was not a Skoda OEM product, so the Skoda company cannot be blamed for the resulting accident.
Telescopic umbrellas that closely resemble the Skoda OEM umbrellas can be obtained for just a few quid, but buyers may regret doing so if the umbrella self-opens and jams a door.
Does the Fabia come with an umbrella or do you have to buy one. Was giving the car a clean yesterday and noticed the storage place was empty.
They come with the umbrella as far as I know. I spoke to 3 Fabia drivers recently at the airport, one had a hired car and wasn't aware of the umbrella one way or the other but all 3 had Skoda stamped on the end and none would open when I pressed the release button after pulling out the umbrella a few inches from the dor to enable pressing it.
I believe it is your wife's Fabia you are referring to and that the car was bought new in 2024 and is a SE L model with 1.5litre motor.
My own Fabia was also bought new in 2024 and is the SE L model (though with 1.0litre motor). It had the Skoda-badged umbrella in the driver's door storage compartment when I collected it. The umbrella's Skoda Part Number is 3V0 860 353 C 9B9 and this ebay advert an example.
https://www.ebay.co.uk/itm/236687787882
This link is to a 2022 CAR Magazine article
CAR Magazine
No image preview
Simply Clever or simply the British weather? Skoda rolls...
Need an umbrella? Want a new car? Buying a Skoda could fulfil both desires
It said
Which models, I hear you ask…
Buyers of the Octavia will be able to specify umbrellas in SE versions and up, but they’ll have to pay £25 for the pleasure. Fabia and Citigo models, in SE trim and above, will have the perm-protectors fitted as standard.
In April, when I was at a local Skoda dealership, they had a new Scala in their showroom. I remarked to the saleslady that the car was missing its 'aero' wheel-trims and she replied "This model does not have wheel-trims". I said "Where are the wheel-nut covers and the wheel-centre Skoda badges, then?" and she said "In plastic bags in the boot" raising the hatchback lid to confirm this was indeed so. So, it's possible that, when a Fabia Mk4 is delivered to a UK Skoda dealership, an umbrella is not present in its door and either comes separately or (as mentioned earlier) should be provided from the selling dealership's own parts department.
The Skoda 'configurator' indicates that all current UK-specification Fabia Mk4 models have the umbrella as standard. It MAY be that, when the Fabia Mk4 was first marketed in the UK in 2021, the umbrella was standard on some models, but a cost-option on others. However, there seems little doubt that, when your wife bought her Fabia SE L in 2024, it SHOULD have come with an umbrella.
I'm guessing that you've asked your wife about this and she said "I didn't know it should have an umbrella". If a Skoda buyer is unaware of this "Simply Clever" (!!!) umbrella feature, they almost certainly won't look for it.
(I recently asked my neighbour about the door-stored umbrella in the new Skoda Enyaq he obtained a few months ago and he said "I've tried using it as an experiment, but probably shan't bother again". I then asked "Does your Enyaq have an umbrella in the passenger door?" and he replied "I haven't checked - how many umbrellas does one need?")
Thanks for the comments, sorry for the delay in replying but we have been away for a few days. We decided to take the Fabia as it doesn't get alot of use and longer runs - I really enjoyed driving the car which as you say is my wifes.
Bit disappointed that it didn’t come with an umbrella given that it was quite expensive with all the extras. I should have checked when we first got the car but hey-ho!
Well blow me down! I've been driving the Fabia quite a bit more just lately and continuing to enjoy it, though the ride can be a bit firm when only two up on poor roads, even though we stuck with the smallest wheels available, probably not helped by the energy efficient tyres which I assume have stiffer sidewalls? Also smaller cars tend to be more firmly sprung to be able to cope with the varying load of one to four/five people which is a greater percentage of the weight of a small car than it of a big car. The suspension in my son's Mazda 2 is also quite firm.
Anyway, I digress. Couple of days ago my wife looked in the glovebox when I was driving and low and behold a Skoda umbrella! The car is coming upto 3 years old now and in mitigation we rarely use the gloveboxes in any of our cars. Maybe I had looked in the glovebox and saw the umbrella when we first got it and thought it better left in there and I'd forgotten?
Edited by VAGCF
There might be another one in the door pocket.....His & Hers then?.
Unfortunately not, I'd already checked there. We do have a couple of non-Skoda ones in the boot though.
