Lost 29-Byte ABS Long Coding — 2014 Škoda Octavia 1.8 TSI
Hello, I accidentally ran a master initialization adaptation reset inside my ABS module using OBDeleven, and it completely cleared out my long coding profile. My module is now showing a persistent 'Control module not coded' fault.
My diagnostic device identifies the blank block template as a 29-byte structure. Could someone with access to an MQB MK100 offline software calculator help me generate my matching configuration code? Here is my hardware and chassis data:
  • Vehicle: 2014 Škoda Octavia Mk3 1.8 TSI (Front-Wheel Drive)
  • ABS Module Component ID: 5Q0907379F (MK100 System)
  • Chassis VIN: <Removed>
  • Transmission Type: [Type here: Manual or DSG Automatic]
Thank you very much for your time and assistance!
Please help me al dash lights are flickering
Please use do not post your VIN or reg number on the public forums, as data scraping may use this information for vehicle cloning or other activities. Only send this information via the PM (Private Messaging) function to trusted members. If the PM function is not yet available to you, tagging the member and asking them to start a conversation will work.
Edited by Briskoda admin.
The coding will likely be VIN dependent so you'll probably be asked to share your VIN by PM by whoever has access to a coding calculator.
