Syphon fuel or not?
Hi,
I have a 2004 1.9 AWX TDI
Last October I parked it up as since getting it (1 owner service history) it has had timing kit and new turbo and then the dmf and gearbox needed fixing
I was unsure if I was going to keep it but I think I might now as only 105k.
Question is should I syphon the fuel (1/4 tank) been sat since October or should I add biocide and top up?
Whats the risk and how realistic is it of causing damage if I just run it on the diesel thats in there and do nothing to it?
@rotodiesel Appreciate any thoughts you have on this
Thanks,
I'd suggest just topping-up the tank with premium diesel and possibly consider an early change of the fuel filter.
If you have biocide then wont do any harm. Have had dreaded diesel bug in my tractor cause it sits for a while without being used. Now use biocide as standard. As mentioned in previous post change filter after a tank or two.
Alasdair
