Battery Problem?
2013 1.6 TDI. Original battery
Monday, drove 200 miles. On reaching destination, car would not lock using the fob. Fob light was working. Drove back home same day. Again, would not lock, used the drivers door emergency lock.
Bought new fob battery.
Today, would not unlock using the fob. Unlocked it maually. Started normally, that's when I noticed a few things.
No interior lights, very faint display on main entertainment screen & the MFD. No front side lights, no daytime driving lights. When I turn on the headlights, they come on, but when I select main beam, the blue warning light comes on but no main beam.
Front windows not working, rears ok. Brake pad warning light came on. Passenger door won't unlock
Drove in normal London traffic for a couple of hours, a/c working normally as well as s/s. Had to lock it manually but only the drivers door is locking.
It all points to a battery problem, but if that was the case I wouldn't expect s/s to work.
I don't have a code reader.
I was thinking of disconnecting the battery to see if the system would re-set itself before getting a garage involved
Before Monday's trip it had been standing for about six weeks.
Any advice please?
Very odd that the SS is still working, but strongly suggest a proper load test on the battery.
  • 4 weeks later...
Small update. Got it into my local garage. They diagnosed the fault as the steering angle sensor which is in the steering wheel assembly.
This part is apparently component protected so has to go to a main dealer.
Booked in for 10th August.
That advice seem strange - wasn't 'component protection' started sometime after 2017?
I don't know. Now at the mercy of the garage☹️ Just count myself lucky this is the first time its had to go into the garage with a problem.
BCM replaced, all ok. I didn't tell them what the other garage diagnosed, wanted to see what their diagnosis was.
At least it was sorted. You can have lots of seemingly unrelated issues if there are problems with a steering angle sensor, wheel speed sensor, etc. It’s not an uncommon thing to lose braking assist, park pilot and other things, all because of something as simple as a dodgy ABS ring.
