GPS ISSUE: Software 330 vs 332?
So, I had some issues regarding the navi with 330, but decided do update to 332. The same thing, navi is off sometimes by 50-500m, sometimes it works. Is there a changelog or anything somewhere? What are the fixes, should i go back to 330?
Those updates are not done on their own, one needs to go to the official shop? Does updating on its own, void warranty?
Do we know when was 330/332 released?
Is there any way to check if the gps is good or bad? There is no option to see how many satellites I am pickig up?
Thank you good people
Edited by LaMpiR
Do the same position errors show on your mobile when using Google maps / Waze when connected / in the car - if yes then your ‘Online Services Controller’ could well be the culprit - expensive bit of kit.........
No. It works perfectly with my Android auto (Google Maps and Waze). Connected over wireless android auto.
Edited by LaMpiR
I'd imagine then that your GPS reception is good and not the culprit - my nav was all over the place on both the car and my mobile - dealer explained that my mobile uses the same onboard data when it connects to the car.........sorry couldn't be more help.
Any additional help guys? :) I've noticed that when in the garage, the problem is much more frequent and when outside, it works most of the time.
On 23/07/2026 at 18:41, Berisford said:
Edited by LaMpiR
  • LaMpiR changed the title to GPS ISSUE: Software 330 vs 332?
I disagree with a previous post that said Android uses the same data as built-in system.
I believe your problem may be a faulty GPS antenna - is this vehicle a Kombi?
It's a combi version. Any way to diagnose it? I tried reseting the system, but now I cannot login as a main user, always getting an error that my profile info cannot be loaded. Everything worked minutes before I reseted the software.
I think you now have two problems.
Your original issue with incorrect GPS positions is very likely to be an antenna problem - it's not uncommon for the roof seal of the 'shark fin' to fail and allow water ingress to the antenna base.
It seems that I do. Today I went from my garage and drove for 30min. Gps had the false location the whole time. I don't use, but it keeps messing my speed sign reading and the warning pops up. I am driving 80km/h with 80 being the speed limit and suddenly it drops to 30 because according to the car, we are in some street which has 30 speed limit and it's 700m away from us. The car was then parked outside for 4h and the drive home, it worked perfectly.
I've updated the system on my own, but will be going to the service center on Wednesday (different issue). Do you think me upgrading on my own voids anything or creates additional issues for me?
Unless alterations were made other than simply carrying out a normal software update, I cannot see how that could affect a warranty in any way.
Actual modifications might if they do spot something non-standard though.
No, just downloaded the file here and updated it over usb, no modifications whatsoever.
Resolves the user login issue at least :) Maybe it needed a bit after the reset.
Edited by LaMpiR
Almost the same symptoms that drove me mad for months - 'Online Services Controller' - the only difference is my iphone was also affected when connected to the Apple Play in the car.......?
That false speed limit business really bugged me - some days the car thought it was on the beach at Skegness - and we live 70 miles from the coast....!
I have a Samsung phone and my wife iPhone and both work perfectly fine.
I like this function to read the speed signs but it seems that it cannot function without the navigation. It pulls the data from the sign and then after 10 seconds, reversed back to gps/map data and that data is wrong. If I had the option to separate the two, just use the system to read the signs, without any input from the navigation, I would never even touch this problem.
Wrong Information
85% the GPS Antenne is damage.
You can check it With a good Diagnose Tool by unit 75
2 hours ago, Cairus said:
Wrong Information
So, I got this from ODBEleven. No modifications were done, as far as I know. Does anybody have experience with such error?
OBDeleven data log
Date: 2026-08-09 07:28
    VIN: XXX
    Car: Skoda Superb
    Year: 2023
    Body type: Estate
    Engine: DTSB
    Mileage: 65495 KM
75 Telematics
    System description: OCUGen3High
    Software number: 5WA035284H
    Software version: 0311
    Hardware number: 5WA035284B
    Hardware version: H22
    Serial number: 0000000301VISM270750
    ODX name: EV_OCUGen3High
    ODX version: 003021
    Long coding: 034820101969A8819005460161052E07
    Trouble codes:
        U112100 - Data bus missing message
            Intermittent
                Date: 2026-08-08 14:11:37
                Mileage: 65492 km
                Priority: 6
                Malfunction frequency counter: 3
                Unlearning counter: 40
                Time Indication: 00
                Voltage terminal 30: 12.4 V
Edited by LaMpiR
If I remember correctly, my error was in Infortainment Cente? Antenna, Short ( Water had got in under the fin)
My car is in the garage and its a very big garage connecting several building, and when I get out, it gets confused and the gps/navi is wrong. Basically it can even go into the wrong direction. Happened again today, drove 30min, parked car for 5h and on the journey home, everything worked perfectly.
