Using indicators occasionally causes windscreen wipers to activate, any ideas ?
faulty stalk if they are on the same one, common problem with modern cars
Seperate stalks in the Karoq. Driven a couple the past week or so.
Yeah they are separate stalks on the Karoq, sounds like its not the easy fix I was hoping for, fortunately its still under Skoda warranty, so I'll be giving them a call, thanks for responses.
Edited by StageHand
Misspelled
Under warranty is good, would probably be around £300+ at main dealers otherwise
Apparantly they are also Model and trim specific too
Wow, pricey, thanks for the info
Can happen at any time if wipers are set to automatic, mine occasionally used to wipe when not raining. Setting in infotainment system, I turned the automatic setting off.
Recently Browsing 1
