Fabia Mk3 1.0 TSI 110HP Spring like noise coming from brake pedal
Hello Everyone.
I have an fabia mk3 1.0 tsi 110hp 6 speed manual 2017 with around 81k km on it, It was bought used at around 78k km.
I noticed the sound after around 1k km of usage after i bought it, i asked the previous owner about it but he either doesnt recall having ever heard it/felt it or forgot about it.
To clarify the issue: When you press the brake pedal you can hear and feel a spring like sound and feeback into the pedal, there are multiples of these sound for one press of the pedal.
I tought it was air in the system, after i bled the air out of all the brake calipers the issue was gone for a little while, but it came bake not long after. ( this air bleed was done twice and after i changed front and back discs and pads and brake fluid )
Does anyone have any suggestions ? i might try to record it to see if the camera picks it up.
I also checked the abs sensor to be clean and properly seated and bolted.
Was there air in system when you bled it. If so try bleeding again to see if there is any air in system again. It may be the brake master thats failing and letting air in
Alasdair
Might be coming from brake light switch?
Alasdair
Alasdair
Brake light switch on cars of this age is just a Hall Effect device bolted into the end of the primary cylinder ("master" does not seem to be very PC these days) - there may well be another mechanical switch on the pedal to let the car's other controllers know that the brake pedal has been pressed - check to find out and spray with a suitable lub - without getting it on the pedal though!
Edit:- the brake servo will have spring inside it, just a thought.
Edited by rum4mo
Sorry for the late reply.
At first there was air in the system but after i bled it there was none left, tough the air might have been present because i might have loosen the bleed valve a bit too much for the first bleed where i used an air compressor, the second time i used the trusty 2 person method cand properly loosened the valve.
I have a recording in which u can faintly hear the spring sound.
Oops send with out attaching.
Streamable
No image preview
Watch unnamed | Streamable
Watch "unnamed" on Streamable.
