TYres - any comments on wear patterns?
I have just replaced all four tyres on my 2018 Superb Estate 2.0i.
I do average mileage (I am not a Rep) and mainly on country roads so low average speeds and local journeys.
A couple of trips per year across to France and use motorways there.
Front set were Nexens which were recommended here. Fitted in January 2024. Mieage not recorded.
Rear set were Goodyear fitted in September 2022 - mileage 69889 km
I was a little shocked to see cords showing through on the Nexens right on the shoulder. This suggests low pressures?? I do run less then recommended due to the harsh ride - maybe 28psi -30psi unless loaded then increase to 30-32psi
The Goodyears show very uneven wear from side to side on the same rear axle. What accounts for that?
Somethindg seems a bit off. Maybe I will get the tracking checked.
I have fitted Yokohams this time.
Your tyre pressures are far too low... Hence the wear.
I'd also suggest you get the tracking looked at if that wear was on the inside edge as it suggests a slightly toe out setting at the moment
However, the key problem will be the pressures your using IMHO.
Edited by skomaz
Do you have a lot of speed cushions on the roads you drive? That sort of wear, if it's just in the inside shoulders as it appears to be, is characteristic of tyres that have regularly been rubbed on speed bumps when you straddle them.
I've just had this query too. Noticed a slight uneven were on the front inside tyres, got the tracking checked. This was a few months ago, squeezing out a little extra time on the tyres. The tracking was only a little bit out. I replaced the tyres this week.
When I was getting the tyres change, they said I didn't do too bad. 20K KM , Lowered on Sports Springs and 15MM spacers all round. Because there is no Camber or Castor adjustment, only Toe, I was told that's all they can do.
Bridgestone Potenza S001
235/40R19 96 W XL
Cloth and wire exposed at the very end.
Edited by defsix
Not many speed humps but plenty of ruts and potholes. I accept the pressures are lower than ideal for the ride comfort. Let this be a warning to anyone who does the same. I will get the tracking checked and see what is out of true.
When I had a new Ford Granada back in the 1990's it ran the original tyres for 40,000 miles. I commuted motorway miles each day but even so that is a little different to today.
Now I have tested the Yokohams and the feel of the car was an instant improvement. It was smoother and quieter. So I recommend them for this car. 235/45 R18 94 W YOKOHAMA BluEarth GT (AE-51) RPB
I've been using the wheel alignment specialist on Leeds Road in Huddersfield, for years.
I took my Superb Greenline Estate to him just after I'd bought it and had 4x new Goodyear eco tyres fitted. He had to loosen the front subframe to get a best-in-the-circumstances alignment, due to the previous owner crashing it. He wasn't able to get the front alignment spot-on, was able to get it fairly well aligned.
34,000 miles later and the Goodyear tyres still had about 4mm left on them. With them wearing more on the inside edge, but nothing as drastic as the photos in this thread.
A nail in the tyre at a funny angle this week resulted in me getting 2x new Hankook Ventus Prime 4's for the front. Otherwise, there's a chance the front Goodyears would have lasted 40,000 miles.
I replaced my 2 front tyres this month, and was also a bit surprised to find them worn down to the threads on the inside edges 😬
They were Goodyear Turanza T005 which I’ve been quite happy with, so replaced them with exactly the same and had the tracking done at the same time. The garage said they’d found the tracking “only slightly” out.
The fact they were so worn down on the inside came as a bit of a surprise as I’d been checking the tread depth regularly…will keep a closer eye on the inside edges in future.
Mine are mostly motorway miles and I usually have them at 2.2 bar. I might try them at 2.5 which I think is listed as the “fully loaded” pressure.
Edited by NikiB
