Which Octavia Scout would you choose?
On 24/08/2026 at 11:32, skomaz said:
Beware - some of the above info is incorrect... all Mk2 Scouts and 4x4's had DPF's, even older PD140 ones, as they were fitted with the BMM 8v engine and not the 16v one without DPF fitted to other variants.
You live an learn 👍
Well, today has been an interesting day.
Collected my, new to me, Scout and when I got home, about 14 miles, someone knocked on my front door to tell me there was a wet patch under the front of the car.
Aaahhh. What the heck.
OIL!!
I cleaned and checked the dipstick and it was DRY!!
Called the garage and it is getting taken back first thing tomorrow.
Plus the Bolero panel has gone blank. Nothing at all. I'll do some digging.
Bugger, was the oil warning light showing on the drive home?
@cwt did you lift the bonnet and check that the oil filler cap was on? Had you checked the oil level and coolant level when collecting car and before leaving with it. Maybe just the drain plug not renewed or washer when serviced or plug cross threaded.
Nope. If it had appeared, I'd have dipped the clutch and killed the engine.
All sorted. When the garage changed the oil fitter, the seal hadn't seated properly. Were they just careless?
Yes but no I didn't check under the bonnet before I drove away. Should I need to?
It was the seal with the oil fitter that hadn't seated correctly. All sorted now, fingers crossed.
Nope, I refer you to my other to save typing them out again.
Here's hoping there was enough oil left in the sump to avoid any damage to the engine by the time you arrived home!
