Side lights
Is the bulb for these strip lights something that can be done by Halfords?
I believe those are LEDs, I think very unlikely to be as simple as 'changing a bulb'
Thanks - shows on screen as side lights - but I don't think they would light much up
Side (or 'marker') lights aren't intended to 'light up' anything - they are a visual reference for oncoming traffic and pedestrians.
Edited by Warrior193
correction
Too dim for that
I had the same warning on my dashboard.
There are sidelight bulbs in there, albeit not worth it. They are 5w bulbs.
You can clearly see your offside one is out. 5 minutes to change both.
Personally I'd avoid Halfrauds. I had a dipped headlight bulb fitted by them. The car failed the MoT a few days later because the "expert" forced the bulb in upside down.
Edited by BionicJohn
Spelling
