Fuse Box Under Bonnet Help
Hi All
Need a favor please, today I was mucking about planning an audio upgrade and I took a look in the fuse box that sits to the right of the battery under the bonnet.
There appears to be what looks like an 80A fuse to the left of the box. It seems to be missing a nut on the 10mm threaded post.
Would some kind soul please take a look in there fuse box and confirm?
Good afternoon Dave, is the 80Amp fuse link under where the nylon fuse extractor is?
That missing terminal post nut clearly looks wrong - what does that fuse protect?
Edited by Warrior193
typo
its not mentioned in the book, it may be wrong or just an unused fitting, I need to know what other peoples Elroqs'look like to know, but your right it does look wrong.
Maybe something is supposed to bolt to it, but its not fitted to my car??
Edited by Tankdave
Almost certainly this.
Other end looks to be riveted in, so standard part of box whether used or not.
Thanks for the tip but none of the fuse boxes match my Elroq one.
I would be very grateful if another Elroq owner would pop the bonnet open and take a sneaky look and see if they too have a missing nut not?
Just trying to avoid driving 50 miles to the dealer to look at another Elroq myself.
Fingers crossed it's the same as mine
Does the stud go down and connect to the thick black wire below?
The one that goes out at the bottom left of your first photo.
If so does that go to the positive battery terminal?
Thanks. AG Falco
Recently Browsing 1
