Puddle of water appearing on floor near to fos wheel
For the last week or so, most mornings I've found a small puddle of water just inside the line of the fos wheel on the garage floor. I'd say that it amounts to about 2 or 3 tablespoonfuls. I've tasted the water and it certainly isn't coolant, and in any event the water level in the expansion tank hasn't changed.
I'm sure it's not aircon derived as I've not used it for about. the same period. I thought it was rainwater being held with somewhere below the windscreen but I've no idea where to look.
To sum up, I don't think this is serious to take the car off the road, but it niggles me that I cannot find a solution.
Hopefully one of you might be able to suggest something. Thanks
grajay, It sounds like it is AirCon related.
This hot weather the Air con is working hard.
Have you got a Sun Roof?
Oh, & what is "the fos wheel" ??? 🙂
Aircon has not been used in the last 4 days. No sunroof.
fos = front-off-side
My only other ideas are -
1) Blocked holes in the plastic cover that sits under the front wiper arms, ahead of the base of the windscreen.
2) Washer bottle or a pipe from it has sprung a leak. That makes more sense as OSF / FOS
O/S/F
N/S/F
O/S/R
N/S/R
But don't loos any sleep over it.
FOS = found overly stiff ?
Edited by Carlodiesel
Thanks for the ideas. I too thought it might be rainwater and I checked the drain hole on the offside but that was perfectly clear, and the car hasn't been out of the garage in any rain for 4 days. It's not the washer bottle either as I have a washer fluid additive and the water is blue and not clear.
Once I find out what it is I shall certainly report back.
I know that my old Audi A2s had a plastic coolant 'pipe of death' in front of the bulkhead that would crack over time and leak, but that was not clear coolant ! If it's not air con condensed water, I'm sticking with the washer fluid idea 😁
2........
Worth checking these drainage holes as they are easily overlooked can get blocked. A few years back I had a small ingress of water and after clearing these I had no more problems. (It didn't make any logical sense but then when do these sort of problems ever make sense?). Not having a sunroof should be a big weight off your mind as leaks from the sunroof have always been a major problem coming up on this forum.
Thanks. When we get some dryer weather I'll pour water onto the windscreen and see the result. There isn't any water in the gulley at the base of the windscreen, but I agree that this MUST be rainwater as there isn't a source of "ordinary" clear water elsewhere.
I keep a drip tray under the front of my Yeti in the garage. There is almost constantly a small pool of water formed - approx under the driver's footwell area - even after a week of non use. I did check once and it is where the air-con drain is located.
Thanks for that. Interesting - much the same as mine.
The strange thing is that my Yeti has been parked in the same garage overnight ever since we brought her home brand new from the dealership and this has only started happening within the last 2 weeks.
Showing her age or perhaps she has a secret little place.
Sorry - in addition to the above I meant to ask the question if whether or not you tied it down to the air conditioning? I would have thought that after a week of non use there wouldn't be any water.
I ask a mechanic today what he thought and he just shrugged his shoulders and said that it could be anything and not to worry.
I've just booked it in for a service in a moths with a garage that specialise in Yetis and other Skodas. Hopefully he might come up with something.
