Broken spark plug - ruined engine? 1.4TSI CZCA
Afternoon all, is this as bad as I think it is?
Bad noise, check engine light, error codes P0300, P0302, P0303. Changed ignition coils on cylinders 2 and 3 which didn't solve the problem so checked the spark plugs. Spark plug on cylinder 2 was missing the tip! It appears to have broken off while in use! The spark plugs were changed 2.5 years ago with Bosch ones. Picture of broken spark plug and video of bad noise attached.
Is my brothers diagnosis of "might need a new engine" an accurate one? I'm hoping I can fish the piece out with a long thin magnet, stick a new spark plug in and then everything will be good as new again!
Car is a Golf 1.4TSI mk7.5 with the CZCA engine.
Cheers
Welcome to the forum.
The noise is probably the missing plug electrode bouncing around inside the cylinder - don't run the engine any more until any foreign bodies have been removed!
I'd suggest using a borescope to inspect the cylinder head, valves and top of piston for damage.
The missing outer electrode is possibly ferrous, you may be able to remove it using a magnetic probe.
Pretty sure they are steel but it may have embedded itself into piston. As warrior193 said do not run engine at all and get it inspected via borescope. Hopefully it will be retrievable without removing head or caused any major damage.
Alasdair
