Front park assist retrofit help required!
Hi. I have installed all the parts now and done the coding I believe is right, but fear I may have a couple of issues.
It looks like I might have a wiring issue with a couple of sensors showing a short. I have extended the loom so may be my dodgy wiring.
Also looks like it’s looking for rear cross traffic alert and ev motor. So I think dataset is wrong on module. (It was from a 1.4 hybrid) not sure if this can recoded or I need a different module.
Any help gratefully received. I use carscanner rather than vcds hence the difference in format.
10. Parking Assistant 2
Application data identification: W5
VAG Part number: 5QA919294G
Software version: 0061
ECU manufacturing date (ASCII): &
ECU serial number: 00015005832014754118
Hardware Part number: 5QA919294
System supplier ECU hardware number: 00015005832014754118
System designation: PDC 8 Kanal
Calibration date (ASCII): 000101
ASAM/ODX: EV_EPHVA18AU3700000
Hardware version: H08
ASAM/ODX version: 009046
FAZIT Identification: ATW-00126.05.20ED020881
Parameter set part number: V03935310QN
Parameter set version: 0001
System abbreviation: J446
ECU manufacturing date (HEX): 200526
Date of last adaptation: 000101
Date of last coding: 200617
Diagnostic mode: 01
Parametrization date: 200617
Long Coding: 1471055851
17. Dashboard
Application data identification: --------------------------
VAG Part number: 3V0920941
Software version: 6422
ECU manufacturing date (ASCII): 151119
VIN: TMBKJ7NP9G7041006
Hardware Part number: 3V0920941
System supplier ECU hardware number: A2C945862040000_D2255
System supplier ECU software number: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
System designation: KOMBI
Calibration date (ASCII): &)
ASAM/ODX: EV_DashBoardVDDMQBAB
Hardware version: 213
FAZIT Identification: VD1-04819.11.1573958407
Parameter set part number: -----------
Parameter set version: ----
System abbreviation: J285
ECU manufacturing date (HEX): 151119
Date of last adaptation: 260329
Date of last coding: 260902
Diagnostic mode: 03
Parametrization date: 000101
Long Coding: 27A5090A2F90A60001887A011000000000000000
Car Scanner ELM OBD2
Version: 2.1.46/2.1.46/iOS
DTC report
Connection profile: Skoda MQB, PQ26: Diesel DPF var.1 [EA288]Date: 9/2/2026 12:27:11 PM
VIN: TMBKJ7NP9G70XXXXX
OBD-II
No DTC found.
10. Parking Assistant 210. Parking Assistant 2
DTCs: 4
1111828 [0x10F714]
B10F714: Left front park assist sensor, Open circuit/short circuit to ground
Geber für Einparkhilfe vorne links-G255 - Unterbrechung/Kurzschluss Masse
Status bits: 1
Priority: 3
Frequency: 2
Unlearning index: 86
Odometer: 213832 km
Date, time: 2026.09.02 12:13:58
Status: Test failed, Confirmed
1112340 [0x10F914]
B10F914: Right front center parking aid sensor, Open circuit/short circuit to ground (GND)
Geber für Einparkhilfe vorne rechts mitte-G253 - Unterbrechung/Kurzschluss Masse
Status bits: 1
Priority: 3
Frequency: 2
Odometer: 213832 km
12656928 [0xC12120]
U112100: Databus missing message
Motorsteuergerät - Motor_EV_01 - kein Signal/keine Kommunikation
Status bits: 1
Priority: 6
Frequency: 1
Odometer: 213832 km
Date, time: 2026.09.02 12:13:38
13639168 [0xD01E00]
Steuergerät für Rear Cross Traffic Alert - RCTA_01 - kein Signal / keine Kommunikation
Status bits: 1
Priority: 6
Frequency: 5
Odometer: 213832 km
Edited by Binx1310
I have ordered a 5QA919294B from a Diesel in the hope that the dataset is plug and play!
Recently Browsing 3
