Front park assist retrofit help required!
Hi. I have installed all the parts now and done the coding I believe is right, but fear I may have a couple of issues.
It looks like I might have a wiring issue with a couple of sensors showing a short. I have extended the loom so may be my dodgy wiring.
Also looks like it’s looking for rear cross traffic alert and ev motor. So I think dataset is wrong on module. (It was from a 1.4 hybrid) not sure if this can recoded or I need a different module.
Any help gratefully received. I use carscanner rather than vcds hence the difference in format.
10. Parking Assistant 2
Application data identification: W5
VAG Part number: 5QA919294G
Software version: 0061
ECU manufacturing date (ASCII): &
ECU serial number: 00015005832014754118
Hardware Part number: 5QA919294
System supplier ECU hardware number: 00015005832014754118
System designation: PDC 8 Kanal
Calibration date (ASCII): 000101
ASAM/ODX: EV_EPHVA18AU3700000
Hardware version: H08
ASAM/ODX version: 009046
FAZIT Identification: ATW-00126.05.20ED020881
Parameter set part number: V03935310QN
Parameter set version: 0001
System abbreviation: J446
ECU manufacturing date (HEX): 200526
Date of last adaptation: 000101
Date of last coding: 200617
Diagnostic mode: 01
Parametrization date: 200617
Long Coding: 1471055851
17. Dashboard
Application data identification: --------------------------
VAG Part number: 3V0920941
Software version: 6422
ECU manufacturing date (ASCII): 151119
VIN: TMBKJ7NP9G7041006
Hardware Part number: 3V0920941
System supplier ECU hardware number: A2C945862040000_D2255
System supplier ECU software number: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
System designation: KOMBI
Calibration date (ASCII): &)
ASAM/ODX: EV_DashBoardVDDMQBAB
Hardware version: 213
FAZIT Identification: VD1-04819.11.1573958407
Parameter set part number: -----------
Parameter set version: ----
System abbreviation: J285
ECU manufacturing date (HEX): 151119
Date of last adaptation: 260329
Date of last coding: 260902
Diagnostic mode: 03
Parametrization date: 000101
Long Coding: 27A5090A2F90A60001887A011000000000000000
Car Scanner ELM OBD2
Version: 2.1.46/2.1.46/iOS
DTC report
Connection profile: Skoda MQB, PQ26: Diesel DPF var.1 [EA288]Date: 9/2/2026 12:27:11 PM
VIN: TMBKJ7NP9G70XXXXX
OBD-II
No DTC found.
10. Parking Assistant 210. Parking Assistant 2
DTCs: 4
1111828 [0x10F714]
B10F714: Left front park assist sensor, Open circuit/short circuit to ground
Geber für Einparkhilfe vorne links-G255 - Unterbrechung/Kurzschluss Masse
Status bits: 1
Priority: 3
Frequency: 2
Unlearning index: 86
Odometer: 213832 km
Date, time: 2026.09.02 12:13:58
Status: Test failed, Confirmed
1112340 [0x10F914]
B10F914: Right front center parking aid sensor, Open circuit/short circuit to ground (GND)
Geber für Einparkhilfe vorne rechts mitte-G253 - Unterbrechung/Kurzschluss Masse
Status bits: 1
Priority: 3
Frequency: 2
Odometer: 213832 km
12656928 [0xC12120]
U112100: Databus missing message
Motorsteuergerät - Motor_EV_01 - kein Signal/keine Kommunikation
Status bits: 1
Priority: 6
Frequency: 1
Odometer: 213832 km
Date, time: 2026.09.02 12:13:38
13639168 [0xD01E00]
Steuergerät für Rear Cross Traffic Alert - RCTA_01 - kein Signal / keine Kommunikation
Status bits: 1
Priority: 6
Frequency: 5
Odometer: 213832 km
Edited by Binx1310
I have ordered a 5QA919294B from a Diesel in the hope that the dataset is plug and play!
You hab vas dongle?(
No unfortunately not.
Is it a new dataset required? There is a guy with odis at a local garage that I can go to if needed. Perhaps you could connect through him or provide dataset for him to load.
I will try the other module I have ordered from eBay and if not will have to look at getting it trying the above!
Some progress made. I thought while I wait for the new module come I would do some fault finding on the sensors. Luckily I started fault finding at the plug end. Starting by checking pinout. It would seem my eyes are not very good at distinguishing between 10 and 18 and I’d managed to pin one side of the plug backwards.
Repinned it and now just the dataset faults remain. Hopefully the swapping if module corrects this.
You make a Lot by the car , buy a vnci Red
If the other module doesn’t work then it may well be cheaper to buy one and get you to connect than get a garage to code it! I will consider it. Although I’m not sure there’s any other retrofits I will do that will need it.
We have some success! New module works without any dataset changes required. No DTC on park assist module.
However I do have 2 DTC on module 17.
I did enable byte 5 bit 4 as per some instructions I found online, but carscanner doesn’t have the same long coding helper that vcds does so I may have done it wrong. @Cairus can you tell from the following what I’ve done wrong?
DTC report
Connection profile: Skoda MQB, PQ26: Diesel DPF var.1 [EA288]Date: 9/4/2026 1:45:16 PM
OBD-II
No DTC found.
17. Dashboard17. Dashboard
DTCs: 2
13636608 [0xD01400]
U101400: Control module incorrectly coded
Steuergerät falsch codiert
ECU incorrectly coded
Status bits: 1
Priority: 2
Frequency: 1
Unlearning index: 91
Odometer: 213909 km
Date, time: 2026.09.04 13:44:33
16776980 [0xFFFF14]
PLA_Status keine Kommunikation
PLA_Status_01 communication error can_error_timeout
PLA_Status_01 keine Kommunikation
Status bits: 1
Priority: 6
Frequency: 1
Odometer: 213909 km
Application data identification: bL
VAG Part number: 5QA919294B
Software version: 0044
ECU manufacturing date (ASCII): 170813
ECU serial number: 00030841861722200441
System supplier ECU hardware number: 00030841861722200441
Calibration date (ASCII): (
Hardware version: H07
ASAM/ODX version: 009035
FAZIT Identification: ATW-00113.08.17EC060080
Parameter set part number: V03935264LH
ECU manufacturing date (HEX): 170813
Date of last adaptation: 170828
Date of last coding: 000000
Diagnostic mode: 03
Parametrization date: 170825
Long Coding: 0471051811
17. Dashboard
Diagnostic mode: 03
1 hour ago, Binx1310 said:
Wir haben einen Erfolg erzielt! Das neue Modul funktioniert ohne jegliche Änderungen am Datensatz. Kein Fehlercode (DTC) am Einparkhilfemodul.
Allerdings habe ich 2 Fehlercodes (DTCs) auf Modul 17.
Ich habe Byte 5 Bit 4 gemäß einer Anleitung, die ich online gefunden habe, aktiviert, aber CarScanner verfügt nicht über die gleiche lange Codierungshilfe wie VCDS, daher habe ich es möglicherweise falsch gemacht. @Cairus Können Sie anhand des Folgenden erkennen, was ich falsch gemacht habe?
Fahrzeugscanner ELM OBD2
DTC-Bericht
Verbindungsprofil: Skoda MQB, PQ26: D codiert
Statusbits
Byte 5 Bit 04 is wrong. Turn off
Byte 13 Bit 0-3 Set to yes ---> High
I have rolled back the byte 5 bit 4 change.
Which bits do I enable on byte 13?
This is what I see on carscanner.
Byte 13 ---> HEX 01
7 minutes ago, Cairus said:
Byte 13 ---> HEX 01
perfection. Thanks once again for your never ending assistance!
You are Welcome
Whats the button highlighted in yellow? I guess the one next to it is to turn the sound on and off.
That's for manoeuvre braking
Ah ok thanks. I looked in manual and couldn’t find it anywhere.
Note, that Maneuver braking doesn't activate at very low speed und cuts off over a certain value.
I can't remember the exact values, but just on the top of the head, I would say it activates from 3-5 km/h to 15km/h. 'Electronic systems gurus', feel free to correct me if these values are wrong.
Otherwise, you can make some test with an empty cardboard box behind your car. It won't be risky. 😉
Edited by Bap33
I cant' remember the exact values, but juts on the top of the head, I would say it activates from 3-5 km/h to 15km/h. 'Electronic systems gurus', feel free to correct me if these values are wrong.
Thanks.
Yes I don’t think I’ll try it out with a wall! Nice to know it’s there if it’s needed!
But you have to Set IT activ in the Car settings.
Also Coding in the Abs
Edited by Cairus
I’ll have a look in the menu.
Do you know which bit/byte in abs needs activating?
Was the question meant seriously?
It was. But now I’m wondering whether it shouldn’t have been.
Because it’s obvious that you would know? Or because I shouldn’t be coding abs?
Byte 24 Bit 05
4 hours ago, Cairus said:
Byte 24 Bit 05
Thanks! All coded and tested using a cardboard box front and back as per @Bap33 suggestion!
Edited by Binx1310
And?... Does it work as expected? I hope it does, as a reward for all your efforts! 😉
Edited by Bap33
