2014 Octavia MK3 Estate 1.6 TDI (110hp) - Front PDC factory options & retrofit?
Hi everyone,
I recently picked up a 2014 Skoda Octavia MK3 Estate with the 1.6 CR TDI 110hp engine. Currently, my car only has rear parking sensors (PDC) installed.
I’m trying to figure out if front parking sensors were available as a factory option on this specific year and trim level, or if front sensors were completely missing on certain specs.
If front sensors were available from the factory, how can I go about sourcing the correct parts to retrofit them? If anyone has successfully added OEM or OEM-style front PDC to a pre-facelift MK3, could you please share links to the exact kits, wiring harnesses, or guides you used?
Thanks in advance for any advice or links!
Look AliExpress
Won't adding front parking sensors also require the PDC module to be changed from a 4 channel one to an 8 channel one?
Yes
