2008 Roomster - Scrubbing noise (Help please)
Hi all. I'm new here, so I hope this is allowed...
We've had a 58 plate Roomster now for around 8 or 9 years and it's always... always always always, made a weird scrubbing sound when driving. It gets higher pitched as speed increases and is at it's worst around 45-50mph. It sounds like a wheel bearing but there's no play in the wheels and a mechanic has confirmed the wheel bearings are ok. It sometimes goes away when new tyres are fitted but it always comes back. I've had the tracking done, no difference (although it was miles out). I also wondered if it could be the transmission (it's auto), but if I shift to Neutral the noise doesn't change. So perhaps not?
Any ideas? It's driving me mad. I can usually diagnose and often fix faults with cars myself, but I'm at a loss with this one.
Not sure on the roomster but on the octavia the rear swing arm bushes can fail/go soft and cause a weird bearing like noise as the rear end is out of alignment and the noise is tyres scrubbing as you drive. There are concentric bolts for the rear alignment to adjust camber and toe etc. Are the rear tyres wearing evenly? If the bushes have failed or worn the rear end may be out and tyres will wear unevenly. I would maybe get a four wheel alignment done and have the rear end bushes checked.
Alasdair
Thanks. The noise definitely comes from the front though and all tyres wear evenly. It's very strange. One to think on thought, cheers.
@jim-mapps Re it being an Auto. Is it a Tiptronic? Has it ever had the box serviced with an oil change? Even though VW / Skoda never gave them as Schedule, Recommendation or advice on Oil Changes.
Um... It's a 6 speed. No flappy paddles but can use the gearstick as a sequential shifter. So I guess so. Never had the box serviced whilst we've had it. I have wondered about the box myself but the noise doesn't change if I shift to Neutral whilst rolling, so I thought maybe not? 🤔
It is a Tiptronic then. I assume a 1.6 petrol.
Could still be a wheel bearing on its way out. Sons was grumbling away but no play in bearing at all. When I compared the old to new the old one it was a bit tighter to turn. Does it change when turning left to right etc.
Alasdair
I thought 1.9 but I could be wrong.
Alasdair
It did seem to be worse when turning right but not anymore. Had it to a mechanic who insisted wheel bearings were fine. I might revisit that with another mechanic TBF.
If it got worse wen turning it may well be a bearing or perhaps a inner/outer cv joint? Perhaps a second opinion as you said.
Alasdair
Booked in for Monday now 🤞
