Skoda Felicia consuming 250 mA when it is turned off
Hello, I have a Skoda Felicia 1.6 model 2000 and I realized the battery was being drained quit fast. I changed it for a new one because it was already very old and then, after seing it was still draining, I measured the current on the possitive cable that goes to the fuse box with every door closed and no light and I measured 250 mA, which seems to me quite a lot for this car. Note that I discarded the alternator and starter since I measured only the positive cable going into the fuse box.
Disconnecting all the fuses didn't do anything, I continue reading 250mA.
In the night, in full dark, I saw that the panel light for oil was slightly on (some current is being drained).
Also one extra thing I did is to disconnect the cable connectors in the fuse box, see picture attached. I discovered that disconnecting BE reduce the current consumption to around 90 - 95 mA (would this be normal for the Felicia?). The car started without the BE cable connector but the oil lamp is not showing at all in the panel, I think this is a bit risky in the long term and I would like to find a proper solution.
My guess is that the oil pump sensor switch is having an issue. I would appreciate any help in this topic.
http://i17.photobucket.com/albums/b61/gokipoki/FELICIA/Feliciafusebox.gif
Edited by gagiuntoli
Update, the battery light and light switch is also slightly turned on when there is not key contact.
Welcome to the forum.
That would tend to suggest that the ignition switch is faulty and is not correctly switching everything off when the key is removed.
Is the foam under the dasboard above the glovebox dry?
Windshield leak is quite common issue on Felicias and water ends up in the fusebox, causing various electrical issues.
No, but the car was in "not so professional" car workshop. I needed to bring it back since the speed indicator was not working after leaving the workshop, the guy there remove the cover at the bottom and went with his hand to behind the speed indicator to reconnect the cable and probably moved something. Since there are 3 things showing this, could be that he remove one mass contact (ground)?
If the ignition switch was fully switching off, I think it a little unlikely that an earth (mass) cable issue would be the cause.
I suppose a welded-closed relay contact could be the cause if the ignition switch tests out as Ok - but I'd be testing that switch first.
The only relay I can think of is R7 (X-contact), which powers wipers, headlights and other power hungry devices. It's also connected to the BE connector mentioned earlier. But it's driven by the ignition switch, so it can be either the switch or the relay.
Yes, I unmount every connector in the panel and was the main light switch (the one lighting in the picture above). It seems a bit burned on the other side.
Recently Browsing 1
