Auto Start-Stop not functioning
Cinch engineer visited as promised. Couldn't find anything out of spec with either the battery or alternator. Although didn't put a charger on to boost the storage.
Other than visiting a main dealer not much else I can do. But prior to that I've a couple of lengthy runs (100miles each way) so will have a see if that makes a difference when compared to the short ones I've being doing.
My less than a year old battery (and car) would makes a very big meal of trying to reach 85% SOC (don't even mention 100%), you can see below that it took 7.5hrs (smart charging) to get a tiny increases in SOC by 2% and a usable battery charge increase of 1AH, the battery energy counter shows a increase of a average of 2.8A over 7.5hrs, 0.37A per hour. My M.meter, in series with the charger showed a charging rate of < 0.2A for the majority of the 7.5 hr charging period. Also, later, on a 25 minute non stop run under varying driving conditions, the DVM showed that the charging voltage never went higher than 13.4V even on overrun and spent most of its time charging at 12.8V.
Maybe a "smarter" smart charger than mine would get the SOC up to 100% eventually, if so, I'd like to see it confirmed by someone with VCDS.
MAS16744-IDE01836 12-volt battery-Battery current -8.825 A
MAS16744-IDE01839 12-volt battery-Battery charge status 75 %
MAS16744-IDE01841 12-volt battery-Battery internal resistance 7.4 mOhm
MAS16744-IDE01842 12-volt battery-Usable battery charge 26 Ah
MAS16744-MAS06086 12-volt battery-Total re-charge 592.4 Ah
MAS16744-MAS06087 12-volt battery-Entire energy throughput 598.1 Ah
MAS16745-IDE01843 Quiescent current management-Battery voltage at rest 12.5 V
After a further 7.5 hrs charging at 12.7, occasionally 13.4V. Charger is a Ultimate Speed ULGD 5.0 C1, (a 5.0A charger)
MAS16744-IDE01836 12-volt battery-Battery current -6.729 A
MAS16744-IDE01839 12-volt battery-Battery charge status 77 %
MAS16744-IDE01842 12-volt battery-Usable battery charge 27 Ah
MAS16744-MAS06086 12-volt battery-Total re-charge 594.3 Ah
MAS16744-MAS06087 12-volt battery-Entire energy throughput 599.0 Ah
Edited by Johngerard
On 30/09/2026 at 10:14, Warrior193 said:
A few trips only of the length you describe may very well not restore the battery charge sufficiently, given the predominant use.
Unfortunately, the smart charging alternator strategy does not appear to recognise intermittent vehicle use and adapt the strategy to bring battery SOC to a higher level - overriding strategy seems to be fuel saving.
IMO, current VAG smart-charge strategy can lead to increased plate sulphation through persistent low SOC unless the vehicle gets regular long runs along with substantial energy micro-recuperation.
My Octavia has a similar use to yours and I use a Ring smart charger occasionally to maintain battery health. I do this at 2-monthly intervals during winter - and approx. 4 to 6-monthly intervals during warmer part of the year (whenever SS stops operating consistently)
Works for me as my 10-year old Moll EFB still tests at almost 90% healthy.
Which model of Ring charger do you use? There looks to be plenty different ones to chose from.
It's a RSC608, but I think this model was updated a few years ago.
How long do you leave the battery on charge at each 2 month charging interval?, does it display the charging voltage and if so do you leave it charging until the voltage falls to some known/recommended level?.
I normally leave it on charge for up to 12 hours or overnight.
Charger is completely automatic (auto recharge) but also has manual settings for 2,4, 6 or 8 Amp charge rate and setting for EFB/AGM or standard LA battery.
Charger switches automatically to maintenance charge rate once it detects the battery is fully charged regardless of charge rate or mode selected.
Charging voltage and Amps are displayed alternately on the screen while it is charging.
2-monthly charges are only during winter if I'm not driving it much.
Edited by Warrior193
clarification
That's interesting, one might imagine that the 2,4, 6 or 8 amp settings are maximum settings, otherwise, if the charge rate (amps) is constant then the voltage must be changing, once my SOC reaches ~ 75% SOC then the charging rate is down to a measured 0.38A as the charger effectively goes to maintenence mode at around 12.7V and the charging rate will fall still lower as the SOC increases so would take days to reach 90% SOC. I would expect your charger to behave similar to mine, below, at least in auto recharge.
Correct, they are maximum settings.
Whereas the auto recharge setting selects the highest, safe charging rate for present battery state.
If your battery is a EFB+ the internal resistance 7.4 mohm seems a little high. Ideally should be around 4-4.5 ish mohm
The first battery scan on this car was only a few days after purchase, April 2026 and its internal resistance was even then 6.8mOhms, it is was 7.4mOhms on 7th Oct (2026), 6 months later.
My almost 8 year old January 2019 Polo wasn't scanned until Sept 2021, (2yrs 8 months old) and its resistance was 6.6mOhms, it was 7.6mOhms in June 2026 (7 yrs 5 months old). Both have 59AH EFB Batteries.
Mine currently reads 4.6 -4.8 70ah size.
10 year old Moll EFB, 59Ah, 320A DIN. 89% healthy at 82% SOC - 4.61 mOhms internal res.
According to obd11 my “batttery aging performance” is down to 70% after 2.5 years. 70ah Varta EFB+ 70ah.
Edited by Micky 32
For context, has this battery ever been charged from external source?
Yep. Charger says full after about 30-40 mins
Going on data from your previous posts, I'd suspect your batteries charge acceptance capacity is down, possibly from hard sulfation of the plates.
Does your charger have a 'recondition' function ?
Yeah it has that pulse setting but i’d say the battery would need to be disconnected to use it.
It wouldn’t surprise me if there’s sulfation. According to the obd11 the battery never goes above 70-75% soc and it gets lots of driving 30k a year.
Edited by Micky 32
It wouldn’t surprise me if there’s sulfation. According to the obd11 the battery never goes above 70-75% soc.
70-75% SOC could well be due to the Smart charging alternator algorithm allowing headspace for regenerative charging - I suspect that this algorithm can lead to irreversible plate sulphation if usual driving conditions never allow the battery to regularly achieve more than, say, 90% SOC.
Can’t find any Battery aging related info for the Jan 2019 Polo but the Jan 2026 one showed, after 2 months, 92% charge related and 89% performance related, 79% SOC.
The Jan 2019 averaged 9.52miles/day, 66.7 miles/week, to 25,395 miles for the first 7.4 years and since hand down just over 6 months ago, 28.75miles/day, 201.3miles/week, 5407 miles, to a total of 30,802 miles
VCDS Data Today 14/10/2026 for the Jan 2019 Polo
IDE01834   Battery voltage 12.172 V
  IDE01836   Battery current -4.958 A
  IDE01837   Temperature of battery sensor 26 °C
  IDE01839   Battery charge status 74 %
  IDE01841   Battery internal resistance 7.6 mOhm
  IDE01842   Usable battery charge 29 Ah
  IDE01843   Battery voltage at rest 12.4 V
  IDE01948   Battery internal resistance not normed 6.4 mOhm
  IDE07681-MAS06086   Battery total charging throughput-Total re-charge 4228.4 Ah
  IDE07681-MAS06087   Battery total charging throughput-Entire energy throughput 4413.9 Ah
IDE03256-MAS06105   Battery adaptation-Rated battery capacity 59 Ah
  IDE03256-MAS06106   Battery adaptation-Battery technology EFB
  IDE03256-MAS06107   Battery adaptation-Battery manufacturer JCB
  IDE03256-MAS06108   Battery adaptation-Battery Serial Number 1111111111
  IDE08347   adapted battery capacity 84 Ah
Edit, Hope this 84AH adapted battery capacity doesn't mean that the BMS thinks its charging a 84AH battery?,
