single door opening/ central locking, when I turn off the car and get out
I want the security aspect of "If I had the doors all centrally locked, and I turn off the car and open my door then the other doors DON'T unlock", but I often find myself turning off the car, opening my door, getting out, stepping to the passenger door behind me, and yanking on a locked handle to no effect 🤦
What would be useful would be if the central locking light (on the button console just in front of the shifter) would stay lit for a few minutes when the doors are centrally locked and I've turned off the car and opened my driver's door, to give a visual indication of "You doofus, if you get out and try to open the rear door now, without whacking the central locking button first, you'll just look like a stupid monkey banging on technology you don't understand!".
Is there a coding option to have the centre console central locking button light stay on for a while after turning off the car/ opening the driver's door, or, really, any other way to get an indication that "the other doors are still locked"?
thanks,
My octavia is the same one press and drivers door unlocks but needs two sometimes three to unlock other doors. Total pain. Keeps telling me to check deadlocks?? Read somewhere something to do with security. I get double press for boot security but why passenger doors?? Must be a way of disabling it.
Alasdair
I haven't encountered that - IFF I (remember to) press the central locking button (once) it will unlock everything.
My (ab)use case is, for whatever reason, at some point I press the central locking button to lock all doors, then when I park the car I forget all about it, stop the car, turn it off, DON'T press the central locking button again, open my driver's door (which will open no matter what the lock condition), and look like an idiot tugging on another door handle (which is still locked).
(The boot will [almost] always open for me, because I [almost] always have the keyfob physically on my person, and the proximity of the keyfob will allow the boot to open no matter the car locking status).
Is there any way to get the central locking system to give me an indication inside the cabin once I've parked - especially, right after I've turned off the ignition - before I get out (maybe as I open the 'locked' driver's door), to remind me that I've still got all of the other doors locked?
Could be the locking sequence is set like that. If its like my display screen (not maxidot) I think you require VCDS/OBD11 to change it. It could also be a failing microswitch in drivers door so the car doesnt realise its been unlocked. Has it always been like that or has it happend recently.
Alasdair
I'm pretty sure it's always been like this. I have it configured in the central console settings to keep the more secure default of NOT unlocking ALL doors just because I open my driver's door.
My issue (and, yes, I have issues!) really is that I need some kind of indicator for when I open my door (which will always open from the inside no matter the lock status/ central locking settings) to remind me "the other doors are still locked"...
