Can’t select drive. Only M
Car drove as normal in drive all evening. Parked for 2 hours, went to drive home but car would not select D. Only way to get drive was to pull back into drive and then over into M. Car drove normally on paddle changing down automatically. Minus paddle not working at all. Selector pulls back to N but unless you immediately shift left to M it just springs back to normal. No fault codes recorded. Any ideas please.
Ive just replied to your post on the Facebook Group. Now I see it a dry clutch DQ20, so my comment about DQ250 is no applicable, if you have TSR and ACC is this a 2024 or later car - in which case take it to the dealer, its still under warranty, still has roadside assistance.
Shows as a 2018 1.5 TSI ACT in profile. So DQ200. & Karoq,s never got the DQ250 6 speed, they got DQ381 7 speed wets.
Edited by Evolution13
It’s a DQ200 7 speed dry clutch. Not under warranty. Always dealer serviced, last done on October 1. It’s only done 21000 miles.
But the Dealership has never touched the DSG while servicing, or have they? Did they con you into having it done? Hopefully not the MCU, but I fear it will be and not just the shifter.
The box has never been serviced. I don’t think I’ve ever been asked. I refused the brake fluid and aircon clean this time. I’m really puzzled. I’d like to find out what the problem is before I send it to the dealer.
Did you try it in S? No way would I go to a Skoda Dealer with a DSG issue. An Automatic Gearbox Specialist is what is needed. And one that does DSG,s. & Brake fluid does need changed sometime in 8 years especially with low miles. I hope it had been done at some point.
I have had the fluid changed twice. Just not this time. Agreed I will look for a specialist. The dealer will probably just change the MCU or gearbox or both!
& maybe £150 plus to diagnose and not omit this if you agreed to have them do the job. Some like Park Skoda Hamilton even farm the work out to an independent because they employ incompetents. Not even all the gear but certainly no idea.
