Adaptive grille ahutter
Just wondering if anyone can confirm that a 2025 Fabia Monte Carlo has adaptive grille shutters. I am led to believe that it does.
I am asking because I have looked at startup but have never seen any evidence of a grille shutting or going through a setup procedure.
Any thoughts on this will be appreciated.
As far as I'm aware, all Skoda Fabia Mk4 cars (irrespective of age) SHOULD have adaptive cooling shutters. They were referred to in this February 2021 Skoda Storyboard relating to the then-new Fabia
https://www.skoda-storyboard.com/en/press-kits/skoda-fabia-covered-drive-press-kit/aerodynamics-innovations-increase-efficiency/
and the information provided reads as follows:
Cooling shutters save up to 0.2 l of fuel per 100 km at 120 km/h
The addition of a new type of cooling shutter has been an important measure. These shutters are actively adjustable slats in the front bumper’s lower air intake. When there is little need for cooling, they close automatically, thereby improving the car’s aerodynamics. This results in fuel savings of up to 0.2 l per 100 km when travelling at a constant speed of 120 km/h. To allow for a high level of cooling or to accommodate short stops, the system opens the shutters so that the maximum amount of air can flow in.
Also mentioned in this October 2021 Skoda Fabia link
https://www.skoda.co.uk/news/details/skoda-fabia-setting-benchmark-in-its-segment
Cooling shutters improve fuel consumption
ŠKODA has installed cooling shutters in the front bumper’s lower air inlet – the first time this technology has been used in this vehicle segment. To improve aerodynamics, actively adjustable slats automatically close when there is little need for cooling. To allow for a high level of cooling or to accommodate short stops, the system opens the shutters so the maximum amount of air can flow in. To further reduce drag, a larger roof spoiler and side finlets optimise the airflow at the rear. At the front, the air is guided through vents in the bumper, known as Air Curtains, in a particularly aerodynamic manner close to the side of the body and the wheels. Twelve panels now cover a larger part of the underbody instead of three, especially in the areas that are crucial for aerodynamics, such as the engine bay and the axles.
(I don't know exactly where they are or how they operate - there's nothing obvious I can see when I look through the bottom and top radiator grilles.)
Thanks, DerekU, for your prompt reply and confirmation that the Fabia has active shutters.
@Alvin600 I can attempt to look up which parts are involved, using your VIN to make sure that only parts fitted to your specific car will be listed.
I'll message you privately, so that you can supply the VIN to me.
You're too new to start such a conversation, but you will be able to reply to my message.
My late-2023-built Skoda Fabia Mk4 SE L model (1.0 TSI motor, DSG transmission) apparently does NOT have an active cooling shutter system.
The images below show the shutter arrangement (a set of horizontal ‘slats’ moved by a small electric motor) and I'd expect to see this when looking through the air-intake grille in the car’s front bumper. But there’s  no sign of it - just a naked radiator.
Looking into the engine compartment from the car's front, the only thing that would impact on the airflow is a group of (unpowered) top-hinged plastic flaps on the left of the radiator that air pressure would cause to swing upwards when the car was travelling at higher speeds - but that’s nothing new or revoluionary as my 2009 Skoda Roomster has something similar.
It may be that all Fabia Mk4 cars had cooling shutters when the range was first marketed, but this feature was dropped at some later date. Or UK-marketed Mk4s never had them, or UK-marketed Mk4s with the 1.5litre motor have them, but 1.0litre cars do not.
As the shutters's stated purpose was to improve aerodynamics and (slightly) reduce fuel consumption, perhaps it was soon decided that the cost and complication of fitting a shutter system could not be justified.
Idle curiosity, but was this ever resolved?
This 2021 BRISKODA topic in the Skoda Octavia Mk4 sub-forum refers to a similar enquiry about the presence (or not) of the cooling shutters.
https://www.briskoda.net/forums/topic/490404-radiator-blinds/
This advice was given
They do exist and are easy to see. Just take a peek below the license plate after the car has been parked and you will see them closed. I always forget to try to see them open.
The shutter unit (pictures in my last posting) apparently has the Part Number 5Q0122323A and the same unit seems to have bee fitted to quite a few VAG Group models (not just Skodas).
I messaged @Alvin600 to offer help via VIN, but received no response.
Pity...
Although I had no difficulty finding drawings/pictures of this part, I couldn't find any photos of it installed in a Fabia Mk4. So I had no real 'feel' for how large the unit was and, if present, what I should expect to see it when looking through my Fabia's front-bumper air intake.
Thinking laterally, I found a couple of videos relating to non-Skoda models and this link was helpful.
https://www.youtube.com/watch?v=zvGYKACL1Kk
This image shows the shutter-unit in place on a VW Jetta
and it's plain that this is a substantial piece of kit that goes behind the front bumper and in front of the lower part of the radiator.
If my Fabia Mk4 had the shutter-unit, this would be obvious when looking through my car's bumper's air intake, but (as I said earlier) there's absolutely nothing there to obstruct/control airflow to the lower part of my car's radiator that is fully visible.
I'm quite glad that the shutter-unit is 'missing' from my car. Like the aero wheel trims, the aerodynamic gains will be quite small and (for me) the shutter feature is one more thing to go wrong and, if it does, a labour-intensive task to fix.
VIN now provided and the ETKA page entitled "Radiator louvre" is greyed out for this car, indicating non-fitment of those items.
I found another Part Number reference and a link that relates specifically to Fabia Mk4 models. This drawing shows the 'radiator louvre' assembly and there's no real doubt about what it looks like and its position on the car.
There's a Skoda Fabia Owners Club Facebook group and (when I have a moment) I'll ask owners of Mk4s if their cars have the cooling-shutter unit and, if so, which country their car was bought in and its age and specification.
My colour edition also have fancy wheel trim inserts ( removable ) fitted to reduce the air flow 🤔
it is for cold winter, where thermostat dont open at all. so airflow thru cooler is not needed. with this blocage engine warms up more quickly.
While that will happen, Skoda's stated reason for having fitted adaptive cooling shutters to the Fabia when the Mk4 version was introduced in 2021 was (as I highlighted in my posting of October 17 above) to improve the car's aerodynamics and reduce its fuel consumption - the same reason for Skoda fitting 'aero' trims to some Fabia Mk 4 wheels.
My late-2023-built Fabia Mk4 SE L car's standard specification included the aero wheel trims, but the trims were dropped from the specification for the following model-year.
My car does not have the cooling shutters and, apparently, neither does the 2025 Monte Carlo Fabia owned by @Alvin600
This May 2026 article compares the Skoda Fabia Mk4 with the Mazda 2
https://carvago.com/articles/car-battle/mazda-2-vs-skoda-fabia
Active cooling shutters are mentioned in the "Aerodynamics and innovation" section of the Fabia review, but I suspect that this is an assumption based on Skoda's press releases rather than the reviewer knowing it to be true.
(Perhaps @BACUPIAN could check if his Fabia has the shutters?)
Big thanks to Breezy_Pete for all your help in this matter; I now know why I can't see the shutters. Also, thanks, DerekU, for your input in this matter.
My 2026 version does appear to have the cooling shutters & on first service around March 2027 will get the dealer to confirm this , no issues up to now !🫠
Thanks for checking - it SHOULD be obvious whether or not a Fabia Mk4 has the cooling-shutter unit.
Interesting that your 2026 Monte Carlo has the shutter-unit, but @Alvin600 's car evidently does not. I believe your car and @Alvin600's have the same 1.5litre engine and DSG transmission, so one might (perhaps!) expect them both to have a shutter-unit, or neither to have a shutter-unit.
Edited by DerekU
I should have stated 1.5 engine & DSG transmission !
Same, mines also the 1.5 with DSG on a 75 plate.
Alvin600
I now see that I got the car ownership back to front !
I did look beforehand at your respective forum Profiles, and yours says that you own a 2025 Monte Carlo (hence 1.5litre motor and DSG transmission) while BACUPIAN's Profile says "2026 FABIA DESIGN EDITION 1.5 TSI AUTOMATIC - FULL WINTER PACK,SPARE WHEEL,MUDFLAPS, F&R DASHCAMS".
I thought that the shutter-unit might be fitted to all Fabia Mk4 models with the 1.5litre motor and not to versions with the 1.0litre motor (my own car has the 1.0litre motor + DSG transmission and no shutters) but that's plainly not the case. Very mysterious...
I have enquired (twice) about this shutter thing on the Skoda Fabia Owners Club Facebook group, but - although I have no difficulty replying to existing threads there - when I create a brand-new thread it gets passed to a moderator for approval and then never appears.
Edited by DerekU
