Where is my oil light!?
I randomly noticed that my oil light didn't seem to be on the dash when I started up. Couldn't remember where it was, or even it it should light up when you first switch on.
Picture below from the short video I made when starting the car.
Can someone advise - should there be an oil light at first, and can you post a picture of your mk2 (petrol) starting up?
What could the problem be?
It probably only illuminates when the level is low (yellow) or the pressure is low (red).
Find and unplug the oil pressure switch and go for a drive, you'll soon see a red light methinks. Usually the only sensor on the engine with just one wire going to it.
If this is a 1.2 TSI, it's near the top of the engine, rear left, plug goes downward onto it.
To see ones lit up look at Google Imaged. Key words Fabia MK3 low oil pressure red can. Or low oil level. Plenty weed posted showing on Fabia MK2 vRS threads.
It may appear in the centre display only when needed. Found this online
My sons mk1 is more basic and has an oil warning light in dash with a really annoying very loud chime every time a warning appears including low on fuel. Everytime it gets low on fuel you think something major has happend.
Alasdair
Thank you Alasdair1, that looks like my situation with the lights, the ignition light is on so the engine hasn't started, but the oil light isn't there apart from the warning (which I don't have). I know it has both level checking and pressure checking, but wasn't sure how it responds to one or both.
Might be worth removing oil sensor wire as breezy pete said to check its actually working. My sons mk1 illuminates red for a few secs after an oil change then off. I am like you cant remember if its there at ignition or not.
Alasdair
Alasdair
Hello, I tried this and with the wire removed there is still no light!
I replaced the oil switch anyway, as this is quite a cheap attempt at a repair, and there is no difference. Also noticed that the old one, when I took it out, has no oil on it, nor could I find any oil in the recess it screws into. Picture below.
So, the oil way to the switch is blocked?
And someone (previous owner) has disabled the red light, so that it doesn't constantly display?
Apart from this, the engine is working fine.
Not sure where I go from here!
Did you drive the car with revs going above 1500 while the connector was unplugged?
No, I shall do if that's what it takes, but I'd assumed that with the connector unplugged the light would be red?
No, it's needs to be driven, or at least revved in neutral at more than 1500rpm. Not sure if bonnet shut and actual vehicle motion required, let us know, please.
Below 1500rpm the switch state isn't monitored.
Ok, I'll try (not tonight, now it's dark) but I thought at idle it would need to alert if the oil pressure somehow fell to nothing. The engine would be damaged at idle.
Also, I thought it should show at a cold startup, just to show the light is working, like the other lights do.
You'd think, but trust me and try what I suggest.
ok, will do, thank you, will try early this week.
No problem.
I'm pretty confident you'll see a red light.
If you haven't already thrown away the original oil pressure switch you took out, keep it as a spare in case the (presumably aftermarket) replacement fails prematurely.
Recently Browsing 2
