Lcc not working
The front camera isn't working, most likely because I bumped into an invisible bollard 🙄
Is there a way of getting to the camera so I can try to fix it before going to an expensive garage.
Ty
Nicky.
The radar sensor is part of the car's Front Assist system and, if fitted, Adaptive Cruise Control (ACC)
Are you talking about the radar in the bumper? Or the camera which is housed behind the rear view mirror?
If it’s radar, then I think it’s an ADAS calibration you need. Happy to be corrected on those that definitely know more about this than me.
If the front radar sensor or its mounts have been damaged or displaced, specialist recalibration is required after any damage is repaired.
Any tiny knock to the radar needs a recalibration. It has to be aligned to within fractions of a degree to the cars centre line. Very much a specialist job.
Lots of info in this thread:
14 hours ago, travs said:
Are you talking about the radyes it is the radar.. ar in the bumper? Or the camera which is housed behind the rear view mirror?
Yes it is the radar.
I'll look at the link and see if that helps ty..
Recently Browsing 1
