Škoda Superb Mk3 (3V) — Genuine 13-pin towbar harness wiring reference + trailer module coding fix
Posting this because I couldn't find either of these anywhere when I needed them — hopefully saves someone else the legwork.
1. Genuine wire-colour reference (confirmed on a 2016 Superb Mk3, liftback, LHD)
This is the actual colour-to-pin mapping from a genuine Škoda pre-wired 13-pin harness, confirmed by physical function testing on the car:
Pin Wire colour Function
1 Black/white Left indicator
2 Grey/white Rear fog light
3 Brown Ground (return 1–8)
4 Black/green Right indicator
5 Grey/blue Right tail/marker
6 Black/red Brake/stop light
7 Purple/black Left tail/marker
8 Blue/black Reverse light
9 Red/yellow Permanent +12V
10 Black Switched +12V
11 Brown Ground (pin 10)
12 — Vacant (CAN/trailer detection, unused)
13 Brown Ground (pin 9)
Worth flagging: genuine wire colours are not standardised across different towbar kit brands or even Škoda model years — this is specific to this harness/car, not a universal chart. If it doesn't match yours exactly, that's expected, not a fault.
2. Trailer module coding fix — wrong-side indicators + missing tail light + brake triggering indicator
Fitted a brand-new genuine trailer control module (5H0 907 383C, Hella, dataset EV_TrailFunctGener3Hella) with the harness above. On first test: only one tail light worked, indicators worked but on the wrong side, and the brake circuit triggered indicator-like behaviour.
Fix: OBDeleven → Control Units → 69 Trailer Control → Long coding. The module shipped with byte 0 = 02. Changed to byte 0 = 01, saved, power-cycled ignition. All three symptoms resolved.
Full working coding string: 01 00 00 02 02 00 14 00
(02 appears to correspond to a non-EU/NA-pattern regional default on a factory-fresh module; 01 is correct for this EU-spec car. No forum post I found had byte 0 confirmed for this exact symptom set — posting it now so it's out there.)
Happy to answer questions if this helps anyone in the same spot.
Recently Browsing 1
