New headlight cannot adjust the dipped up enough
Help needed
The led DRL on my right drivers side head light failed as the headlight sprung a leak at the seam between lense and plastic case next to the wing
Bought new skoda headlight from skoda dealer and fitted it but the dipped beam is just far to low
Odd but the nylon adjuster looked as though some tool had already been on it so I was suspicious
The main beam was ok with a tweak to its adjuster which was in perfect order
I have rotated the dipped adjuster until i feel resistance. ( anti clockwise was lifting beam seemed odd direction as main was clockwise to lift ?) but it dipped beam still pointing down onto road and far lower than than it should be
2016 Fabia with the dome lense over the dipped beam bulb
Is this the white 6mm hex/allen key fitting?
What about the in car headlight aim adjustment wheel?
Projector type headlamp assembly.
Thanks. AG Falco
The motor on the headlight moves up and down as I change the dash level setting to - or 3. Max to min.
Yes the white 6mm hex/allen key fitting (is the only adjustment available for the dipped beam)
The dipped beam was far too low and I just can not lift the beam up enough with the adjuster
The headlamp is nicely seated back in the body and with even gaps around it to the body work and it looks to be the same as the other side so it is sat correctly
Can’t see what I can do , I don’t want to force the adjuster as soon as I felt resistance I stopped But it’s far to low to start with
Checked bulb seated correctly too
bought it mail order from a skoda dealer I don’t see what I can do other than return it as defective
And the aim moves at the same time?
These bulbs are not easy to fit in my experience.
They need a twist to completely locate in the correct position.
Perhaps check this and compare to the other side.
You can't see the bulb from the front which can help with this.
I use a mirror from the back of the housing to check.
Bulb goes up then beam reflects down?
Thanks. AG Falco
