Radio cutting out new starter motor
Hello,
Had a crank no start. Bosch starter motor reconditioned fitted. Car starts each and every time for a month since fitting.
Wife noticed radio (Kenwood aftermarket) loses power on cranking and resets or stays shut down. Radio fitted 1 year ago and only shut down when battery was knackered. Turning off fan, lights had no effect. Radio loses power when starting every time, warm or cold engine.
Looks like a voltage drop. Dash lights unaffected. I already cleaned all earth points in engine bay. I checked the negative battery cable to suspension turret earth. Put extra cable on it in case breakage (jump lead). Radio still loses power momentarily forcing reset. Presets not lost.
Battery is healthy and reading over 12.6v
AI Google says to fit a capacitor plus loom behind radio to drop the voltage drop. Anything else I can do? The battery is bigger than needed. 540Cca and it got at least 100 cca so I'm thinking is there a weak ground.
Radio needs ignition on to power up - switched live. Could red and yellow wires be wrong way around, but then radio would be on all time = flat battery on constant live.
Also seen a little brown wire slightly frayed on neg battery terminal. It is used for control systems on car and provides clean voltage unlike earth points. Could that be to blame?
Any ideas appreciated.
Check the battery voltage while engine is being cranked - likely that voltage is dropping too low during engine crank.
From memory the yellow wire I think is permanent live and red is from ignition. The yellow wire is there to keep settings etc. It may be that the Kenwood is more susceptible to voltage drop. Check that the yellow wire is getting 12v with ignition off.
Alasdair
Radio wires - yes I checked with multimeter at time.
AI says the aftermarket are susceptible to voltage drop and under 10.5v they shut down.
Suggested I buy add on that has loom and small capacitor to take up the drop in voltage on cranking.
Car wouldn't start now - the spade connector in starter motor had popped out. Any suggestions on holding it in? I crimped spade connector for tighter fit but it was already as tight as it would go. The aftermarket starter motor might have had some wear on its male spade end. I used duct tape but it came unstuck. Soldering a bit extreme and hard to get to.
Don't think this is related to radio though. Thanks
Ps found this for starter motor relay wire.
1K0973751 1 Pin Prewired Starter Connector for VW AUDI Seat.
Currently there is just a female spade connector. Will this part fit? Methinks not....
Edited by bmbmdmb
Check the spade connection sizes. It could be that the starter has a slightly smaller spade than one than the spade connector. There normally 4.8mm or 6.3mm
Alasdair
Meant to add check the main feed from battery to starter is tight. If its slightly loose it may explain V drop. You could also check voltage accross battery when cranking to see how far it drops.
Alasdair
I'll check battery voltage drop across battery. Earth to starter is tight and I cleaned contact. I had a wiggle of cable when fitting starter motor and no sign of breakage and what I could see of cable was uncorroded.
AI says 6.3mm spade which from memory fits what I saw. The spade is loose in direction it pushes on/off, not sideways if that is how spade sizes change (on width)?
The tightness of the fit wasn't great before on old starter. I'd spotted looseness some years ago and I'd put duct tape holding cable in place, just in case.
Assuming the wire connector is female, the best idea would be to replace the connector - being careful not to shorten the wire too much if slack to loom is limited.
The wire is an extension of about 10cm to give some slack for engine movement probably fitted due to problems earlier on with it coming lose when ASZ engine made. This is BLT.
When the car returns home do I measure width of spade or it's length?
Ta
Edited by bmbmdmb
Width of spade. Its normally 6.3mm. It could be that it has become slightly too wide so by crimping the rolled sections wont make it hold very well. Either replace it or try and squeeze the rolled sections together slightly to reduce overall width Check the earth on the radio as well. If replacing make sure you use one suitable for the thickness of wire. From memory blue is 1.5-2.5mm and yellow is 3-6mm. Thats the cross sectional area of wire.
Alasdair
Edited by Alasdair1
Crank voltage across terminals dropped to 10.30V , that's in the 10 to 10.5V range that AI said aftermarket radios shut down.
Earth connector - had a look diagonally across engine bay. Only thing I can think of is there is a circular washer that is crumpled / rippled. Might have put it on wrong way place reducing contact area? Other earth points don't have this.
Order as follows nut - washer - starter earth cable contact - earth point.
Maybe washer goes between last 2?
I could add another earth cable between starter and earth point?
Starter live wire spade - the starter has a smaller spade. Oddly
I'd suggest having the battery properly tested first.
I would think its nut washer cable contact point is correct. The washer is normally used to distribute tightening force and stop nut coming loose. Replace spade terminal to match spade or you can get convertors but probably better to replace. It could be that the new starter is pulling more current and will draw less once worn in a bit.
Alasdair
I've replaced the extension live wire to starter motor. Even with correct sized spades I've had to crimp with pliers to tighten fit. Duct tape just in case.
I used extra earth to starter from battery neg. Radio still cut out. I'm on my own so no voltage readings.
I did a drop test on battery. Ign on dipped beam, blower on fogs on. 12.01v
Which is possibly questionable for a Feb 2026 battery.
Resting voltage is always above 12.6v
Alternator giving 14.2v iirc
Last battery lasted 6years and was resting at 12.3v but drop tested to 11.6v or lower. It failed to hold charge dropping to 12.1v resting. Soon after power steering light came on. Heavy steering etc.
Could be battery? Coincided with cold weather arriving.
I've got battery tester but last batteries on other cars that were on way out were passed and told me to recharge. Only when cell collapsed does it fail . Shop replaced battery FOC (2 year old Bosch and 5yr warranty).
Edited by bmbmdmb
With engine off I reckon 12.6v to 12.01v with what you said on is normal so pretty sure battery is good. Blower plus dip and fogs will draw a fair bit of current. Does yours have an earth strap from Gbox to chassis and has it been checked.
Alasdair
Turned off blower and all fogs.
Side and dipped lights got 12.15v on battery.
Whereabouts behind glovebox is earth point?
Sorry its Gearbox. On my sons mk1 its a braided strap.
Alasdair
What about just turning the radio off before starting engine?
I tried turning off radio before starting. It turned off! It is illuminated even when on standby but ignition off. So, not fully turned off if you get my drift. I think I've seen the lights go off on cranking. The crank is immediate unlike the old starter, although that was good. I've delayed cranking waiting.for ignition lights to extinguish and some more. Also, I've waited for radio to boot up, then crank. All result in radio cutting out and restarting.
Blower fan, lights all off etc
Taking it to motor store I bought from. It is a yuasa 760cca ybx5096 which is bigger battery than original spec.
Incartec 10-602 make a voltage regulator I'm thinking of buying.
Edited by bmbmdmb
Motor shop says battery is good using tester 78% health.
Reckon radio should be completely off with ignition off and key removed. Try swapping yellow and red wires to see if it makes a difference. It could also be a bad ignition switch thats cutting power to radio when cranking.
Alasdair
Alasdair
When car key removed from ignition the radio goes into its power down mode. Pressing power button with key removed results in radio staying powered off as it always has.
I believe radio is correctly wired- it has been behaving flawlessly for 1 year. Problems recently occurred when new starter motor fitted.
If I reverse the red and yellow wires the radio, currently running off switch live, will then be powered on the permanent live.
This probably would stop the radio cutting out but would leave the radio powered on all the time resulting in a flat battery?
As the radio worked before it must be something else. Reckon it may be the starter drawing more current as its new. Do the headlights blower etc switch off when cranking.
Alasdair
