1 hour ago, imart143 said:
yes on eco 2 engines, but on evo 1 engine it is unlikely, The V-belt tensioner does not allow tension in the other direction, the belt could fall off, while the evo 2 tensioner is completely different.
instead,
With an eBay memory module installed behind the dashboard button, your alternator operates in a steady, conventional charging mode rather than aggressive regenerative mode—and it is actually healthier for your 12V battery over time.
How Your Alternator Works Now
  • Simulates a manual button press. Every time you turn on the ignition, the module sends a quick electrical pulse that mimics you pressing the physical Start-Stop "OFF" button.
  • Aggressive coast-only charging is disabled. Because the car's Energy Management System sees that Start-Stop is turned off by the driver, it abandons the fuel-saving "recuperation mode" (where it lets the battery drop to ~80% charge while cruising so it has empty room to absorb braking energy).
  • Constant, steady voltage. Instead of fluctuating wildly between 12.2V (cruising) and 14.8V+ (braking), your alternator now outputs a steady ~13.8V to 14.3V during normal driving.
  • Smart protection remains intact. Because the battery sensor on the negative terminal is still plugged in, the ECU still monitors battery temperature and health, tapering off the voltage once the battery reaches near 100% state of charge so it never overcharges.
What This Means for Your Car
  • Longer 12V battery life. Standard recuperation cycles constantly undercharge AGM/EFB batteries (keeping them around 75%–80%), which accelerates sulfation and shortens battery lifespan. Keeping the battery near 100% with your memory module typically makes it last noticeably longer.
  • No fault codes or side effects. Unlike unplugging the battery sensor wire, the car treats this as a completely normal user action, so all safety and convenience systems work properly.
  • Minimal fuel difference. Keeping the alternator engaged continuously adds a tiny mechanical load to the 1.5 TSI engine, resulting in a negligible fuel consumption increase (typically around 0.1–0.2 L/100 km).
Given the reference to Ebay module, presumably this charging mode isn't OEM standard ?
actually it is no charging mode, its much simple. it is switch for off button that works on/off after install. so you turn on or off start stop and it stays in that position when you like to change just press it again.
https://www.ebay.co.uk/itm/405999540429
Edited by imart143
Going through the obd11 data it claims the battery has a total energy throughput of 14,500ah.
VW claim when it reaches 16,800ah( for a 70ah efb battery) the battery is coming to it’s end of life.
You multiply 70ah x 240 for EFB’s. For Agm’s you multiply the 70ah x 360.
the same here about the battery. my octy vrs 12/2023 , 47100 km --- battery is very weak. i have ctek cs the best on market. charged 20x but now its not possible. EfB is ****ty battery . u need to buy AGM yuassa or exide is the best . maybe it is the problem with ECU. i dont know that . service dealers in croatia are not willing to check anything . they just say u have power . its fine. but its not when i have to charge every month
I am also charging it every month and it works okay.
Mine is just about on 4 years and working fine. The car is often left sitting in the garage unused for several days at a time so I always keep it 'trickled' on the CTEK charger with the car locked (to assure full shut down).
Edited by SouthernComfort
This almost exactly 8 year old (Jan 2019) petrol Polo with a 59AH EFB battery is working perfectly, last set of readings (below) taken last June after 7.5 years, all short runs up to passing it on to our daughter in April, only ~ 40K KMs on it then, now > 50K Kms, wife always inhibits stop/start, I use it as I see fit.
IDE01834 Battery voltage 12.193 V
IDE01836 Battery current -4.950 A
IDE01839 Battery charge status 77 %
IDE01841 Battery internal resistance 7.6 mOhm
IDE01842 Usable battery charge 28 Ah
IDE01948 Battery internal resistance not normed 6.0 mOhm
IDE07681-MAS06086 Battery total charging throughput-Total re-charge 3890.7 Ah
IDE07681-MAS06087 Battery total charging throughput-Entire energy throughput 4091.0 Ah
Edited by Johngerard
After only 2.5 years my ah is over 14,000ah total energy throughput.
14000Ah is ~ 15.3Ah/day, won't knock a measurable dent in the battery's SOC even if it fell by this amount.
Some blame the frequent starting in Stop/Start for a lot of battery problems but if you think of it, each start only takes a fraction of a AH, if you run a VCDS log on battery current, you will catch most of it, mine, shows between 179A and 200A, a 2sec crank will still only consume, 200*2/3600, 0.11AH, your (hot) diesel might pull say a max of 350A for a (we'll give it) 3sec crank, 350*3/3600, 0.29AH, the glow plugs will consume possibly as much even though only on very briefly, if at all, with a hot engine.
Even though we all profess to hate this smart charging and a max of 85% SOC etc, I would only worry if the battery is deep discharged and also, more worrying, its internal resistance, which is inevitable. If you accept that say 9.5V is the minimum starting voltage required and on a cold morning your diesel requires 350A and that the standstill battery voltage is 12.5V, voltage drop is 3.0V, internal resistance would have to be, (3/350)*1000, 8.57mOhms, so maybe set somewhere around there as your warning flag.
If you forget all that jazz above, just do what I have done for over 60 years, get someone to crank the engine while you watch the voltage on your multimeter with the probes on the battery terminals.
I think the majority of damage done to batteries is done in the parking lots where the cars can sit for months with the batteries in deep discharge. I have a April 2026 Polo and I reckon the battery has suffered this fate.
9.5V is not minimal starting voltage. it is a voltage drop during cranking. if you have 9.5V battery, it wont start at all..
Correct, Voltage while actually cranking.
Car has been driven ~ 5,200 mils in past 6 months, readings taken today, below.
59AH EFB Battery Original from Jan 2019
11:41:09 Mileage: 31,734 miles
IDE00019 Voltage terminal 30 12.4 V
IDE01836 Battery current -4.372 A
IDE01837 Temperature of battery sensor 24 °C
IDE01839 Battery charge status 85 %
IDE01841 Battery internal resistance 8.0 mOhm
IDE01842 Usable battery charge 31 Ah
IDE01843 Battery voltage at rest 12.6 V
IDE01948 Battery internal resistance not normed 6.8 mOhm
IDE07681-MAS06086 Battery total charging throughput-Total re-charge 4345.8 Ah
IDE07681-MAS06087 Battery total charging throughput-Entire energy throughput 4535.9 Ah
I noticed my car records the minimum cranking voltage drop in the gateway module. Most mornings it reads 7.90-8v. I have seen it drop to 7.5v. Not sure how accurate that is
I left my car in for ceramic coating and when i picked it up the next morning it dropped to 6,6v and a **** load of low voltage codes.( i’m sure they were opening and closing doors while cleaning)The lowest i have seen on a battery tester cranking test was 7.9v.
Edited by Micky 32
Have you got VCDS or similar?, if so, can you record readings like these:
Battery charge status (85 %)
Battery internal resistance (8.0 mOhm)
Usable battery charge (31 Ah)
Battery voltage at rest (12.6 V)
Recently Browsing 1
