Tyres and punctures
I had to take my car to the garage recently and the technician pointed out that I had a screw embedded in my tyre.
I was surprised because I hadn't had any puncture warning.
Next stop therefore was my local tyre supplier who said that yes there was a screw there but the Pirelli tyres fitted on my Skoda from new are 'Seal Inside' technology so that the tyre creates a seal around any foreign object.
So the good news is that I don't need to do anything about the screw other than monitor it.
The bad news is that you cannot repair these tyres, only replace them if damaged.
Had not come across this technology before but it seems to work.
I'd strongly advise against leaving the screw in place, in some cases this can result in sudden failure if foreign objects in the tyre heat up excessively while driving.
Just checked - foreign object in tyre during MOT test is normally considered a serious defect and therefore a fail - following that logic, knowingly driving on an unsafe tyre could result in serious issues.
Remove it and check if there is leakage by using soapy water in the area.
If there is leakage, there are 'self-vulcanising' repair plugs that can be inserted into the hole - much safer than leaving the screw in place.
Edited by Warrior193
added information
I also would not leave the screw in the tyre.
You can repair 'Seal Inside' tyres, but it is more effort/time.
The seal needs to be removed from the inside of the tyre where the screw is.
Do not remove the screw without plugging the hole straight away.
Thanks. AG Falco
Self seal means that You do not have to reipair the tyre.
Hoewvet, you still should remove the screw.
I had such dituation and the screw was jyst simply removed. Then the tyre was pumped to higher pressure for few minutes an that was it.
I have driven after that for 6 motnths and paid attention to pressure - there was no drop in the pressure at all. So it works.
Regarding repairibg such tyre - yes it can be repaired. However, it is work and time consuming as they have to remove the sealant.
As long as it is just small puncture - repair makes no sense as the self seal feature works ok.
Recently Browsing 1
