Rear fog light(s) not receiving 12V
Hello,
I would need help at fixing the rear fog light. Bulb is intact, the switch works and on the dashboard the indicator light for rear fog lamp turns on but at the bulb socket there is no power. Might be related that long time ago some cable burned and also the left driver door's panel lamp is not turning on when door is openend nor does the door open sensor is working for the driver's door.
the front fog lights work properly
When you say no power have you checked to a reliable earth or just accross bulb contacts?
Alasdair
I checked bulb socket contacts but the ground in the socket is shared with the other 3 lights (night/brake, turn and reverse) which work properly
Try the cable connector itself not the contacts but if theres still no voltage its probably a broken wire as I think the fuse does front and rear unless its the actual switch for the rear thats failed? Not sure what route the cable takes from rear
Alasdair
Meant to add if yours has a towbar fitted they sometimes were fitted with a microswitch in connector to disconnect rear fog light to stop back glare from trailer. If its failed it could be the cause.
Alasdair
Recently Browsing 1
