Battery issue or?
Hi all
For about a week or so the temperatures have dropped significantly (from 10-15 degrees C during the day down to negative values during the night). When I start my car for the first time in the day either in the morning or later I switch on the ignition, wait a few secs and then press the brake and start the engine and at that moment I get a warning such as ACC unavailable, manoeuvre braking unavailable and they disappear in 1-2 seconds and everything is working. The car is starting normally, the battery is an original VW 75Ah battery fitted brand new 2 years ago by an authorized dealer. My question is could this be a momentary drop in voltage and should I be worried since I have some trips lined up in the next couple of weeks?
Could be, the cold weather is hard on a battery. It could also be that certain sensors are a bit slow to respond during very cold weather hence the 2-3secs delay. My Octavia mk2 idle revs during the last cold spell were high but seem to have returned to normal now its above freezing.
Alasdair
I have noticed that at odd times a couple of the assistance features aren't immediately available but they appear after a few seconds. I suspect its moisture on the radar sensor and the moisture/condensation on the windscreen.
More likely to be the drop in battery voltage during cold crank - then the voltage recovers when the alternator kicks in.
Drop is normal to 9V when cranking.
My 1.5 is 14 months old, twice it has failed to start along with a stream of unrelated error messages. The first time (new car 3 days old) after leaving for a few hours it did start with fewer error, several restarts cleared the messages. Next day I took it to Skoda, they spent about an hour on it and found no faults, they said it must have been a glitch!
6 months later it did the same, but multipule restart attempt and opening / closing locking doors, the error went away and the car started.
Each time this happened, the battery could have been low, the first time being in the Skoda garage, the second time it was frosty. I do not use the car regulary, so once a week I put my battery charger on it to charge it to 100%
I believe that the cars alternator only charges up to about 80% to allow for some regen. Not good for starting, not good for the life of the battery. I think there are several posts on this in the forum.
9 volts is a bit low when cranking - I'd suggest a battery test if it's falling that low.
From memory, around 10 volts is a healthy limit.
9.5V then.
Cold start this morning, measured at the power outlet socket in the car. Initially 12.2, then 10.3 when cranking. Battery 14 months old, fully charged by external charge yesterday.
UPDATE: this morning the engine wouldn’t turn over at first and then it started normally on the second go. Drove the car normally during the day but decided to visit the dealership. They ran diagnostics and the battery came back as faulty. Putting in a brand new one at this moment. I’m just a bit surprised that an original battery only lasted two years and one month, I don’t even live in an area that experiences extreme low temperatures and I’m wary of stuff such as start/stop system and such.
Edited by specturow
Even if you don't use SS, the alternator charging algorithm stays the same - which can mean the battery SOC never gets above 75%, particularly if relatively short trips are common.
Surprised the battery wasn't dropping below 10 volts if it's faulty.
Check with them that the replacement is correctly adapted (coded) to the BCM.
Edited by Warrior193
added information
This is why I charge mine with a CTEC charger about once a week. 75% is not good for the life of a battery. I think manufacturers do it to save small amounts of fuel in the published tests, but I don't think it helps in real world MPG.
I believe it's actually to allow headspace in battery capacity for regenerative charging - but it is ultimately about tweaking emissions and fuel use.
Agree that it's almost certainly not ideal for battery life if SOC rarely achieves 90+%.
Recently Browsing 1
