Tyre Pressure Sensor fault when tyres changed
Hello,
Hoping that someone out there has either come across this issue themselves or can kindly offer some considered advice.
We own a 2023 Skoda Scala 1.0 litre which has covered 13,000 miles. The car was fitted from new with 'Nexen' branded tyres which still had at least 3.5 - 4mm of good tread.
Three out of the four original tyres developed cracking on the outside shoulder of the tread which was brought to our attention during the car's first MOT (October 2026) Although not a MOT fail or even advisory we were asked just to keep an eye on the situation in case the cracking went deep enough to expose the steel fibres.
In the interests of safety we decided to change the three 'cracked' tyres but kept the fourth tyre as it was clear of any similar cracking.
On the first long journey after changing these tyres, the TPMS light came up on the dash even though all four tyre pressures had been checked no more than two days previously. Likewise the tyre has no obvious nail or similar object causing a slow puncture.
I have again checked all four tyres and re-set the dashboard computer but any reasonably long journey keeps lighting up the TPMS on the same rear offside tyre. Bizarrely short trips around town don't cause any such issues.
Hard to imagine it's a faulty pressure sensor given the proximity in time of when the three other tyres were changed.
Many thanks.
Your car does not have TPM sensors in the wheels, the system is part of the ABS system as far as sensors at each wheels hubs. If you are resetting the TPMS correctly then, maybe the issue is a wheel bearing overheating and heating the wheel and increasing the tyres heat and increasing the tyres pressure. Only causing a warning on longer runs. So not a tyre pressure loss, less circumference of a tyre but increased circumference. Next time there is a warning try to stop someplace soon as and see if the wheel seems too hot. Or just try resetting the TPMS again.
Is the rear offside tyre the remaining original? If so it's likely to be due to the different rolling circumference of that worn tyre compared to the three other new tyres.
Yes, the only remaining original tyre. As mentioned in my original post, I think it too much of a coincidence that it is just this tyre that keeps showing up on the screen as a loss of tyre pressure.
If it's the original tyre then the difference in wear will be the cause and it'll need to be replaced to resolve the TPMS logging a loss of pressure.
Personally I only replace tyres in axle pairs unless absolutely necessary.
Edited by skomaz
Thank you for the advice.
You can fit a different tyre like a spare or even have tyres at different pressures so total diameter / circumference and set the TPMS to remember that and get no TPMS warning if no change after set. Try it. It is how it is. You do not need to have a constant TPMS warning while running a little mis-sized spare wheel as Skoda sells / supplies.
Direct TPMS was available on some models as a cost option - but indirect (ABS) type is more likely on your vehicle.
Presumably your TPMS does not display actual tyre pressures ? - if not, your system is indirect type.
As to the original tyre size being the issue and a different circumference. Simples if not directional then swap to other rear side and reset the TPMS and see if warning changes. If so then no question best replace that tyre.
Agreed. But experience tells me that even doing that and resetting the TPMS it'll sometimes eventually throw a warning on a long journey.
If you have a full size spare put that on and see if it makes any difference as the chances are its new if you only done 13k. Tyres dont seem to last as long these days and tend to crack with age. I always replace mine when I see any cracks. If you dont have a full size spare maybe buy a full sized rim and put the part worn tyre on it and get a new tyre.
Alasdair
@skomaz I have had the opposite experience when doing it to prove a point to people that did not believe you could run different t pressures or sizes on FWD VW group cars. And running different sizes myself front and rear on MK2 Fabias.
Edited by Evolution13
Reset through the infotainment under the car settings, tyres menu, not the dash display. Set all four to the door placard cold pressures, store them, then drive normally so it relearns. Also measure the old tyre's tread against the new ones, a few mm difference can trigger this system.
No there is no pressure limit shown, just an orange symbol on the dash indicating that the rear offside tyre has lost some pressure.
Or increased it's pressure from the setting it was set at when the likes of a sticky brake or bearing failing causes a wheel to heat and the air in the tyre. Lets ignore that in your case, but that is something not uncommon that triggers a TPMS warning. So not jus a loss of pressure and circumference and more wheel rotations. Less wheel rotations can be detected. But then when 1 new tyre with full tread gets fitted to a car with this TPMS maybe even over inflated you can reset the TPMS and it logs that as a thing.
